Old 18-04-2005, 03:49 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default help me ... i waana hide !!!
i connect to the net using my reliance FWP. its a dial up connection.
is it possible to hide/use another IP address my IP address while surfing the net?
i use a stand alone machine.
p3 winXP pro
256MB ram
mekalodu
iinfi is offline
Old 18-04-2005, 03:53 PM   #2 (permalink)
Well ur ip is assigned to U by the ISP through which U r made accessible to internet ..
& ip tht U get is a temporary one! so everytime U connect to the net ur ISP provides U with a new ip ...
I think U cant change the ip bcz it might happen like U & some other person with different connection have same ip! bcz U chnaged it on ur own ...
newayzz i still could get the purpose Y U wanna do that?
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 18-04-2005, 03:56 PM   #3 (permalink)
mekalodu
iinfi's Avatar
will tell u the answer when we chat on Ymessenger .... lol
and when did u return to the forum???
mekalodu
iinfi is offline
Old 18-04-2005, 03:59 PM   #4 (permalink)
i think u wanna surf anonymously ....
in that case if u wanna hide ur IP address browse web sites thru this link....
http://proxify.com/
grinning_devil is offline
Old 18-04-2005, 08:18 PM   #5 (permalink)
Even zone alarm has an option that allows you to hide your IP.
**** happens
pradeep_chauhan is offline
Old 18-04-2005, 08:25 PM   #6 (permalink)
why need title?
bharathbala2003's Avatar
can u enlighten me on this topic
bharathbala2003 is offline
Old 18-04-2005, 08:34 PM   #7 (permalink)
sure, i have the free zone alarm installed go to overview -> prefrences and click on hide my IP when applicable and Hide the last octet......
That does the trick (i think...)
**** happens
Old 18-04-2005, 09:45 PM   #8 (permalink)
why need title?
ok now i have done it... any means to test if its working
Old 18-04-2005, 10:21 PM   #9 (permalink)
mekalodu
iinfi's Avatar
yes i wanna surf anonymously ....
well i dont think zone alarm hides IP address ....
there is an option no doubt ....
but if u goto any payment gateway then my ip address is logged ...
better way is ..... i know a site ..... www.chelseafc.com
its chelsea futball club's website ....
go there .... goto chat or forum ......frm the links provieded ....
and there your IP address is logged ...
u can check if thats ur ip address ....
and everytime my IP adderss is logged correctly ...
mekalodu
iinfi is offline
Old 18-04-2005, 10:23 PM   #10 (permalink)
QA Juggler
saROMan's Avatar
hmm...well wat u can do is go to any of these sites...get a working proxy Here..then u can check if its working or not Here OR Here
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 18-04-2005, 10:24 PM   #11 (permalink)
mekalodu
iinfi's Avatar
thanks grinning devil and saroman ....
i will use it and tell u how it is ....
cheers
mekalodu
iinfi is offline
Old 18-04-2005, 11:51 PM   #12 (permalink)
Fresh Stock Since 2005
The option is Hide IP when applicable......... So i don't think it is a very good idea.....................
khattam_ is offline
Old 18-04-2005, 11:53 PM   #13 (permalink)
cheers
You will most probably tell that it was too slow.................. Most of proxies slow down internet access, but if remaining stealth is important than speed, then you can use proxies
khattam_ is offline
Old 19-04-2005, 03:22 PM   #14 (permalink)
mekalodu
iinfi's Avatar
yeah its slow
mekalodu
iinfi is offline
Old 19-04-2005, 06:55 PM   #15 (permalink)
Guess how u can change ur ip for every 2 secs
h4xbox is offline
Old 19-04-2005, 07:24 PM   #16 (permalink)
eh?Sire correct me if i'm wrong but doesnt enabling that option hide the last octet from zone alarm update server while downloading new updates?
Now that i'm not on ZA,anybody would like to check before & after enabling that option head right here What is My IP?.
Oh btw anonymous proxies are simply not a safe solution by any means.I'm talking about those hundreds of free proxy lists that you get scattered all over the internet.It certainly hides your IP from the destination host but all traffic travels through the anon proxy,anybody there with a packet sniffer & a little knowledge of TCP/IP can easily make a profile of your session through the proxy including usernames,passwords & stuff that we all are paranoid about.
I'm not aware of any paid proxy services which are known for their trustable services.
Rather than risking ones personal information I would suggest hardening the OS,disabling un-necessary services,having a software firewall if necessary & a appropriate anti-virus.
www.Oobertech.net
digen is offline
Old 19-04-2005, 08:10 PM   #17 (permalink)
Sorry my mistake did not read the fine (or shall i say BOLD) print
**** happens
Old 19-04-2005, 08:44 PM   #18 (permalink)
Ahha now its my turn...no formalities please
www.Oobertech.net
digen is offline
Old 19-04-2005, 10:10 PM   #19 (permalink)
Well even with all your suggestions Digen if I dont use an anon proxy then I my IP will be known by the end client. Which is the one you try and avoid in most cases. So unless there is some other way to hide your actually IP, getting your IP is gonna be easy.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 19-04-2005, 11:43 PM   #20 (permalink)
Very correct dude there is no other way to hide your IP but consider this what will anyone with my IP do?
Scan for open ports,perform fingerprinting on various services if any present,get info of the ISP i'm on.
Then after getting sufficient info search for vulnerabilities/exploits for the respective service/s[note:i've taken for granted that there are services present on my computer like http server[IIS 5.1] blah blah] then try getting in to posses root access.The above holds good unless we are taking into account worms,trojans,key loggers which will call back to the attacker.Lets also keep out from the discussion DDoS[Distributed Denial of service attack] & your machine being added as a zombie.
Now lets consider a everyday joe scenario,will he/she host a http server? does he/she needs a service to be running?will he/she needs her own email server running 24/7?
I'm sure the answer is no.Because just knowing your IP isnt gonna do a hell of good to any script kiddie scanning one helluva port range unless & untill you have something running which helps.
My point being why do you have to purposely hide the IP if you dont have anything to show?
The things I have suggested in my earlier post seems completely satisfactory with security in mind but its a other way around.
Few people know what exactly happens with a anonymous server in the middle.Its actually kinda a "man in the middle" attack.Taking for granted a page that says "full anonymity" makes you feel you are safe? Nope a jackass maybe sniffing all the traffic by just looking at the logs & making merry out of it.
How do you trust them? Blind faith?
Trust me but not all free anon servers may be like this but its kinda hard to differentiate when you know nothing about it unless we are talking of paid anon services which is a different story.
I had written my earlier post w.r.t the original poster who says hes on dial-up & provided no info as to why he wanted to hide his IP.
Note:The case I've considered above resembles people who surf the internet,download,email,chat blah blah.
For others who host web servers,public services online its a complete different scenario.
www.Oobertech.net
digen is offline
Old 20-04-2005, 12:35 PM   #21 (permalink)
In both scenarios the pitfalls exist. Typically a user who uses the net will mostly have the following running on his machine. Instant Messengers(yahoo, MSN), a web browser and might use a FTP client. If all other services are shut off then a prospective cracker will look to hack into these services. Plus many tracking services use your IP addresses to track your activity online. Lets say "unwanted" sites . If I use a anonymous proxy server then tracking it to my end IP is usually extremely difficult. However if you do use an Anon-proxy and I am crazy enough to login to my emails well ur asking for trouble arent u Both has its pro's and cons. And as you correctly mentioned the reason as to why he wishes to remain anonymous has not been mentioned by the user!!!!!
AMD 64 3500+ Venice
icecoolz is offline
Old 20-04-2005, 01:04 PM   #22 (permalink)
Plus many tracking services use your IP addresses to track your activity online. Lets say "unwanted" sites Wink . If I use a anonymous proxy server then tracking it to my end IP is usually extremely difficult.
Agree with you partially what but harm can they cause with that lil piece info they've got?
Maybe its something that I'm not aware of,perhaps you could shed some light on the same.
I believe in a simply analogy,IP address is your home address locking your doors & windows is the utmost priority.
www.Oobertech.net
digen is offline
Old 20-04-2005, 02:41 PM   #23 (permalink)
mekalodu
iinfi's Avatar
wanted to be anonymous jus to test the site/software whether it works and to know how it works ..... i have never used it though i have heard about proxy servers this that etc.
thats it.... nothing else
thanks everyone for the valuable info.
mekalodu
iinfi is offline
Old 20-04-2005, 11:03 PM   #24 (permalink)
Let ppl discuss what they want dude.......... If your problem is sloved, its good, it may be helpful for other ppl too.............. And its good to know more than you already do........................................
khattam_ is offline
- by tkin
