Old 18-04-2005, 12:08 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Smart Drive ???
while doing a fresh installation of win XP, i was asked abt smart drive ...
whots a smart drive ???
ax3 is offline
Old 18-04-2005, 03:18 PM   #2 (permalink)
aadipa's Avatar
WinXP setup when started from DOS mode (using i386\winnt.exe) copies lot of files before installation starts. SMART DRIVE is a disk caching tool which speeds up file copy process in DOS mode.
When you start WinXP setup by booting into the CD-ROM with original boot sector, smart drive is loaded automatically, but when u start the setup from DOS mode, or with bootable cd having DOS floppy boot sector which, then calls Winnt.exe from autoexec.bat of DOS floppy, you need to load SMART DRIVE manually.
More info about smart drive SMART DRIVE
Get your smartdrv.exe from Win98, copy it to floppy.
To install WinXP now issue following commands.
A:\smartdrv.exe
G:\i386\winnt.exe
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 19-04-2005, 11:01 AM   #3 (permalink)
ax3
ax3's Avatar
thanx a lot ...
u r great ...
... W H O T ...
ax3 is offline
- by tkin
