Old 18-04-2005, 09:52 AM   #1 (permalink)
Default DVD Woes
I have a Samsung DVD Drive and an LG cd writer installed in my pc. Recently i borrowed a pioneer DVD writer from my friend to take backups from my 80Gb HDD. I took backups on 6 dvd's and after burning checked them on the pioneer drive, it worked fine. But now if i load the dvd into my old samsung drive i get a message "Windows cannot read from this disk. the disk might be corrupted, or it could be using a format that is not compatible with windows". if i load other dvd's (digit etc) it works fine.
I also took backup of my mp3 collection and that works in my plain old dvd/mp3 player but not on my samsung dvd drive. And as i mentioned all the dvd's that i took backup in worked well in the dvd writer.
Since i returned the dvd writer, i am stuck!
shyam911 is offline
Old 18-04-2005, 10:14 AM   #2 (permalink)
kl_ravi's Avatar
Can you post few more details like writing speeds, Software used to burn the disc etc....
kl_ravi is offline
Old 18-04-2005, 10:29 AM   #3 (permalink)
I user Nero Burning Rom and i wrote at 4x speed. in a 8x dvd. i was told writing at high speeds might cause problems so i wrote at 4x speed only
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 18-04-2005, 10:32 AM   #4 (permalink)
What format were the DVDs you burned in? DVD-R?? There are multiple standards for DVDs and it might be that your DVD drive does not support the format in which the DVD was written. Please post details about your DVD drive and the type of media used.
Nemesis is offline
Old 18-04-2005, 11:47 AM   #5 (permalink)
The format was normal data format. I used Moser Baer dvd-r 8X. i burned them as normal data compilation, just as i do in normal CD-R. My DVD drive is a ordinary Samsung DVD ROM SD-816B
shyam911 is offline
Old 18-04-2005, 08:35 PM   #6 (permalink)
Woah... This might sound crazy but i tried my dvd on a couple of other drives, a samsung dvd drive the same as mine at my friends place and a sony dvd drive at my cousin's place and the dvd's seemed to work well there. except mine
shyam911 is offline
Old 18-04-2005, 10:26 PM   #7 (permalink)
QA Juggler
saROMan's Avatar
hmm seems that ur Samung Drive is a Bit old and thats why cant read the DVD's which seem to be burnt at higher Speed...try tweaking ur DVD ROM by means of some Tools to Run at Higher speed say 16X and then try...Hope it works
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 19-04-2005, 07:11 AM   #8 (permalink)
kl_ravi's Avatar
Just run the Nero Info Tool and post the screenshot here (Yours' , Your Friends etc). I have posted screenshot of My CD RW & Virtual Drive below....
kl_ravi is offline
Old 19-04-2005, 08:38 PM   #9 (permalink)
kl_ravi i'll post the screenshot soon. but i found out one thing. When i checked my DVD drive under DVD Region properties > it said Region 5 and changes left 4. Earlier when i bought it, it said "No Region Selected". I am not sure how it changed (could have happened when i loaned it out to a friend). How do i change it back?.
shyam911 is offline
Old 20-04-2005, 10:59 AM   #10 (permalink)
DVD Drives can be set to particular regions in order to play DVD movies. You get only 5 changes and after that, the Region Code is locked to the last one. So let it stay at Region 5. There are ways to get around the Region codes like using software such as DVD Region Free or flashing your firmware. As far as I know, you cannot go back to the No Region Selected setting.
Nemesis is offline
Old 20-04-2005, 11:59 AM   #11 (permalink)
Thanks Nemesis, but i need one more clarification will SW like DVD Region Free allow me to access data DVD's?. Or is it only for Video DVD. The main issue is i had backed up my projects and other stuff (mostly doc's pdf and exe's) in those dvd's.
shyam911 is offline
Old 22-04-2005, 10:41 AM   #12 (permalink)
Guys i really need some help here. I am able to view all dvd's (both video and audio) without any hassles and also without the help of any 3rd party tools like DVD region free. But i am not able to access that particular set of data dvd's that i burned using my friend's pioneer dvd burner. And the worst thing is that those dvd's work on all other drives except mine
shyam911 is offline
- by tkin
