Old 18-04-2005, 08:12 AM   #1 (permalink)
Default ERROR OPENING VCD [HEEELP....]
some one please help copy a vcd .I got the following error message while opening it.
any software to recover this cd ? iam using a LG RW and a samsung DVD ROM
this vcd works fine on a vcd player
vijaythefool is offline
Old 18-04-2005, 08:29 AM   #2 (permalink)
I too had some problems like this so used nero 6 to write an image of the disk .iso to the hdd and then later saw the contents by using an emulator. The disk is probably scrached / dammaged and nero with its new error detection / correction might help.
**** happens
pradeep_chauhan is offline
Old 18-04-2005, 08:54 AM   #3 (permalink)
what is an emulator ? would nero be able to read the cd ?
Old 18-04-2005, 10:26 AM   #4 (permalink)
kl_ravi's Avatar
Use Alcohol 120%. If Alcohol can't fix it.... You can't do much other than obtaining a new VCD.
Just in case you want to recover the AVSEQ01.DAT file, you can use Badcopy Pro or ISO Buster.
kl_ravi is offline
Old 18-04-2005, 11:51 AM   #5 (permalink)
after making an image should i burn it to another cd ?
Old 18-04-2005, 12:14 PM   #6 (permalink)
vignesh's Avatar
Yes
vignesh is offline
Old 18-04-2005, 12:26 PM   #7 (permalink)
if i make an iso and burn it it will contain the same stuff causing the error message i guess .. see this thread on copy protect
http://www.thinkdigit.com/forum/viewtopic.php?t=18322
Old 19-04-2005, 07:26 AM   #8 (permalink)
kl_ravi's Avatar
The thread you are pointing to is for copying a copy protected CD (Which is illegal if you want to distribute it).
If the VCD is copy protected you can use Alcohol 120% to make an Image by specifying the type of protection form the datatype combo box. Now while burning, you can choose not to make a copy protected CD or leave the field as it is (in which case) you get an exact replica of the original CD...!!!!
Just make sure that you are doing all this for genuine reasons...
kl_ravi is offline
Old 19-04-2005, 12:07 PM   #9 (permalink)
i ve download alcohol 120 % but it did not install. so i ve tried with nero wich created an image with lots of errors an a warning
here is the log file created
Vijay
Vijay
1A23-8177-8031-9549-0544-0032
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/19/2004 10:11:48 PM
ahead WinASPI: File 'D:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero Version: 6.6.0.8
Recorder: < Image Recorder> Version: Not available - HA -1 TA 0 - 6.6.0.8
Adapter driver: <Virtual Device> HA -1
Drive buffer :
CD-ROM: <HL-DT-ST CD-RW GCE-8525B >Version: 1.01 - HA 1 TA 1 - 6.6.0.8
Adapter driver: <IdeChnDr> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : TSSTcorp DVD-ROM TS-H352A IdeChnDr Port 0 ID 1 DMA: Off
DiskPeripheral : SAMSUNG SP0802N IdeChnDr Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8525B IdeChnDr Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp DVD-ROM TS-H352 I: CDRom0
HL-DT-ST CD-RW GCE-8525B H: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 509MB (522032kB)
Free physical memory: 402MB (412104kB)
Memory in use : 21 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.4.2005
CD Copy
11:43:04 AM #1 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO (enabled: CD)
11:43:04 AM #2 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
Insert the original disc.
(Medium in drive: Unknown. Medium required by compilation: CD.)
11:43:06 AM #3 Text 0 File Reader.cpp, Line 127
Reader running
11:43:06 AM #4 Text 0 File Writer.cpp, Line 122
Writer Image Recorder running
11:43:06 AM #5 Phase 48 File dlgbrnst.cpp, Line 1832
Analyzing disc
11:43:06 AM #6 CDCOPY -1 File CDCopy.cpp, Line 1907
The CD is copyrighted
11:43:10 AM #7 Text 0 File CDCopy.cpp, Line 2123
_Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
Track 1: 0 0 ( 0:02.00) 1109 1108 ( 0:16.58)
Track 2: 1109 1261 ( 0:18.61) 334393 334392 ( 74:20.42)
11:43:10 AM #8 Text 0 File CDCopy.cpp, Line 840
Copy options: copy on-the-fly: ON
read ISRC/MCN: OFF
use jitter correction: OFF
data options
ignore read error: ON write defekt blocks OFF
read raw data: OFF read r-w subchannel data: OFF
audio options
read indexes: OFF read r-w subchannel data: OFF
source disc does not look like CD Extra
01. 0 - 1259 = 1259, data (TRM_DATA_RAW_MODE2, block size 2352)
02. 1261 - 334393 = 333132, data (TRM_DATA_RAW_MODE2, block size 2352)
11:43:10 AM #9 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using CD-R/RW media
11:43:10 AM #10 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 445499 ( 99:01.74)
Last address to be written: 334392 ( 74:20.42)
11:43:10 AM #11 Text 0 File DlgWaitCD.cpp, Line 271
11:43:10 AM #12 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: Image Recorder;
CD type reading failed
ATIP Data: ?
11:43:10 AM #13 Text 0 File DlgWaitCD.cpp, Line 433
11:43:10 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE2_2336 (1 - Data (mode 2))
2 indices, index0 (150) not provided
original disc pos #0 + 1109 (1109) = #1109/0:14.59
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 1109 blocks [Image Recorder]
1: TRM_DATA_MODE2_2336 (2 - Data (mode 2))
2 indices, index0 (152) not provided
original disc pos #1261 + 333132 (333132) = #334393/74:18.43
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 333132 blocks [Image Recorder]
11:43:29 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [Image Recorder] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x20; Session Closed, disc fixated
Tracks 1 to 2:
1: TRM_DATA_MODE2_2336, 2336/0x00, FilePos 0 350400 2941024, ISRC ""
2: TRM_DATA_MODE2_2336, 2336/0x00, FilePos 2941024 3296096 781492448, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1109 | 2 | 0 | 0x41 | 0x00
1261 | 2 | 1 | 0x41 | 0x00
334393 | lead-out | 1 | 0x41 | 0x00
11:43:29 AM #16 Phase 65 File dlgbrnst.cpp, Line 1832
Burn process started
11:43:29 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
11:43:29 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 1 (not relocatable, no disc pos, no patch infos, orig at #1261): write at #1261
11:48:33 AM #19 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF1000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0x80 0x1D 0x00 0x00 0x1C 0x58 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x64 0x00
11:48:35 AM #20 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFEB00
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0x80 0x35 0x00 0x00 0x01 0x58 0x00 0x00
11:48:35 AM #21 CDCOPY -12 File TrackPFile.cpp, Line 271
Unrecoverable read error at
51:01.04
11:48:35 AM #22 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 229429 to 229429
11:48:36 AM #23 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0x80 0x39 0x00 0x00 0x1C 0x58 0x00 0x00
11:48:37 AM #24 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF98E0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0x80 0x48 0x00 0x00 0x01 0x58 0x00 0x00
11:48:37 AM #25 CDCOPY -12 File TrackPFile.cpp, Line 271
51:01.23
11:48:37 AM #26 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 229448 to 229448
11:48:37 AM #27 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0x80 0x55 0x00 0x00 0x1C 0x58 0x00 0x00
11:48:38 AM #28 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF46C0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0x80 0x5B 0x00 0x00 0x01 0x58 0x00 0x00
11:48:38 AM #29 CDCOPY -12 File TrackPFile.cpp, Line 271
51:01.42
11:48:38 AM #30 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 229467 to 229467
11:48:56 AM #31 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA8 0xCD 0x00 0x00 0x1C 0x58 0x00 0x00
11:48:57 AM #32 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF86A0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA8 0xDA 0x00 0x00 0x01 0x58 0x00 0x00
11:48:57 AM #33 CDCOPY -12 File TrackPFile.cpp, Line 271
53:19.59
11:48:57 AM #34 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 239834 to 239834
11:48:58 AM #35 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA8 0xE9 0x00 0x00 0x1C 0x58 0x00 0x00
11:48:59 AM #36 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x01 0x00 0x00 0x01 0x58 0x00 0x00
11:48:59 AM #37 CDCOPY -12 File TrackPFile.cpp, Line 271
53:20.23
11:48:59 AM #38 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 239873 to 239873
11:49:00 AM #39 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x05 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:01 AM #40 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x14 0x00 0x00 0x01 0x58 0x00 0x00
11:49:01 AM #41 CDCOPY -12 File TrackPFile.cpp, Line 271
53:20.42
11:49:02 AM #42 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFA200
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x15 0x00 0x00 0x01 0x58 0x00 0x00
11:49:02 AM #43 CDCOPY -12 File TrackPFile.cpp, Line 271
53:20.43
11:49:02 AM #44 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 239892 to 239893
11:49:03 AM #45 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x21 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:04 AM #46 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF4FE0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x28 0x00 0x00 0x01 0x58 0x00 0x00
11:49:04 AM #47 CDCOPY -12 File TrackPFile.cpp, Line 271
53:20.62
11:49:04 AM #48 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 239912 to 239912
11:49:05 AM #49 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFFD40
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x3B 0x00 0x00 0x01 0x58 0x00 0x00
11:49:05 AM #50 CDCOPY -12 File TrackPFile.cpp, Line 271
53:21.06
11:49:06 AM #51 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03B00660
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xA9 0x3C 0x00 0x00 0x01 0x58 0x00 0x00
11:49:06 AM #52 CDCOPY -12 File TrackPFile.cpp, Line 271
53:21.07
11:49:06 AM #53 Text 0 File TrackPFile.cpp, Line 214
Read error from LBA 239931 to 239932
11:49:09 AM #54 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xAC 0x69 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:10 AM #55 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF2B60
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xAC 0x6C 0x00 0x00 0x01 0x58 0x00 0x00
11:49:10 AM #56 CDCOPY -12 File TrackPFile.cpp, Line 271
53:31.73
11:49:10 AM #57 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 240748 to 240748
11:49:20 AM #58 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB3 0xF5 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:21 AM #59 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB3 0xF5 0x00 0x00 0x01 0x58 0x00 0x00
11:49:21 AM #60 CDCOPY -12 File TrackPFile.cpp, Line 271
53:57.52
11:49:21 AM #61 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242677 to 242677
11:49:22 AM #62 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFBD60
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x08 0x00 0x00 0x01 0x58 0x00 0x00
11:49:22 AM #63 CDCOPY -12 File TrackPFile.cpp, Line 271
53:57.71
11:49:22 AM #64 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242696 to 242696
11:49:23 AM #65 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x11 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:24 AM #66 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF7460
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x1C 0x00 0x00 0x01 0x58 0x00 0x00
11:49:24 AM #67 CDCOPY -12 File TrackPFile.cpp, Line 271
53:58.16
11:49:24 AM #68 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242716 to 242716
11:49:25 AM #69 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x2D 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:26 AM #70 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF2240
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x2F 0x00 0x00 0x01 0x58 0x00 0x00
11:49:26 AM #71 CDCOPY -12 File TrackPFile.cpp, Line 271
53:58.35
11:49:27 AM #72 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x30 0x00 0x00 0x01 0x58 0x00 0x00
11:49:27 AM #73 CDCOPY -12 File TrackPFile.cpp, Line 271
53:58.36
11:49:27 AM #74 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242735 to 242736
11:49:28 AM #75 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFD8C0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x43 0x00 0x00 0x01 0x58 0x00 0x00
11:49:28 AM #76 CDCOPY -12 File TrackPFile.cpp, Line 271
53:58.55
11:49:28 AM #77 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242755 to 242755
11:49:29 AM #78 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x49 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:30 AM #79 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x56 0x00 0x00 0x01 0x58 0x00 0x00
11:49:30 AM #80 CDCOPY -12 File TrackPFile.cpp, Line 271
53:58.74
11:49:31 AM #81 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF8FC0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x57 0x00 0x00 0x01 0x58 0x00 0x00
11:49:31 AM #82 CDCOPY -12 File TrackPFile.cpp, Line 271
53:59.00
11:49:31 AM #83 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242774 to 242775
11:49:32 AM #84 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x65 0x00 0x00 0x1C 0x58 0x00 0x00
11:49:33 AM #85 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF3DA0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x6A 0x00 0x00 0x01 0x58 0x00 0x00
11:49:33 AM #86 CDCOPY -12 File TrackPFile.cpp, Line 271
53:59.19
11:49:33 AM #87 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242794 to 242794
11:49:33 AM #88 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x7D 0x00 0x00 0x01 0x58 0x00 0x00
11:49:33 AM #89 CDCOPY -12 File TrackPFile.cpp, Line 271
53:59.38
11:49:34 AM #90 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFF420
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x03 0xB4 0x7E 0x00 0x00 0x01 0x58 0x00 0x00
11:49:34 AM #91 CDCOPY -12 File TrackPFile.cpp, Line 271
53:59.39
11:49:34 AM #92 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 242813 to 242814
11:51:31 AM #93 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x15 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:32 AM #94 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x1A 0x00 0x00 0x01 0x58 0x00 0x00
11:51:32 AM #95 CDCOPY -12 File TrackPFile.cpp, Line 271
68:38.62
11:51:32 AM #96 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308762 to 308762
11:51:34 AM #97 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x30 0x00 0x00 0x01 0x58 0x00 0x00
11:51:34 AM #98 CDCOPY -12 File TrackPFile.cpp, Line 271
68:39.09
11:51:35 AM #99 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x31 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:35 AM #100 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308784 to 308784
11:51:36 AM #101 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFC680
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x45 0x00 0x00 0x01 0x58 0x00 0x00
11:51:36 AM #102 CDCOPY -12 File TrackPFile.cpp, Line 271
68:39.30
11:51:36 AM #103 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308805 to 308805
11:51:36 AM #104 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x4D 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:37 AM #105 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x5A 0x00 0x00 0x01 0x58 0x00 0x00
11:51:37 AM #106 CDCOPY -12 File TrackPFile.cpp, Line 271
68:39.51
11:51:38 AM #107 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308826 to 308826
11:51:39 AM #108 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x69 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:40 AM #109 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x85 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:41 AM #110 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x85 0x00 0x00 0x01 0x58 0x00 0x00
11:51:41 AM #111 CDCOPY -12 File TrackPFile.cpp, Line 271
68:40.19
11:51:41 AM #112 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308869 to 308869
11:51:42 AM #113 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0x9B 0x00 0x00 0x01 0x58 0x00 0x00
11:51:42 AM #114 CDCOPY -12 File TrackPFile.cpp, Line 271
68:40.41
11:51:42 AM #115 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308891 to 308891
11:51:43 AM #116 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xA1 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:44 AM #117 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xB0 0x00 0x00 0x01 0x58 0x00 0x00
11:51:44 AM #118 CDCOPY -12 File TrackPFile.cpp, Line 271
68:40.62
11:51:44 AM #119 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308912 to 308912
11:51:45 AM #120 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xBD 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:46 AM #121 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF5900
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xC5 0x00 0x00 0x01 0x58 0x00 0x00
11:51:46 AM #122 CDCOPY -12 File TrackPFile.cpp, Line 271
68:41.08
11:51:46 AM #123 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308933 to 308933
11:51:47 AM #124 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xD9 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:48 AM #125 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xDB 0x00 0x00 0x01 0x58 0x00 0x00
11:51:48 AM #126 CDCOPY -12 File TrackPFile.cpp, Line 271
68:41.30
11:51:48 AM #127 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308955 to 308955
11:51:49 AM #128 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFE1E0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xF0 0x00 0x00 0x01 0x58 0x00 0x00
11:51:49 AM #129 CDCOPY -12 File TrackPFile.cpp, Line 271
68:41.51
11:51:49 AM #130 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308976 to 308976
11:51:51 AM #131 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB6 0xF5 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:52 AM #132 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB7 0x05 0x00 0x00 0x01 0x58 0x00 0x00
11:51:52 AM #133 CDCOPY -12 File TrackPFile.cpp, Line 271
68:41.72
11:51:53 AM #134 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFAB20
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB7 0x06 0x00 0x00 0x01 0x58 0x00 0x00
11:51:53 AM #135 CDCOPY -12 File TrackPFile.cpp, Line 271
68:41.73
11:51:53 AM #136 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 308997 to 308998
11:51:55 AM #137 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB7 0xF1 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:56 AM #138 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB8 0x07 0x00 0x00 0x01 0x58 0x00 0x00
11:51:56 AM #139 CDCOPY -12 File TrackPFile.cpp, Line 271
68:45.30
11:51:56 AM #140 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 309255 to 309255
11:51:58 AM #141 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB8 0x45 0x00 0x00 0x1C 0x58 0x00 0x00
11:51:59 AM #142 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB8 0x47 0x00 0x00 0x01 0x58 0x00 0x00
11:51:59 AM #143 CDCOPY -12 File TrackPFile.cpp, Line 271
68:46.19
11:51:59 AM #144 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 309319 to 309319
11:52:00 AM #145 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB8 0x61 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:01 AM #146 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB8 0x72 0x00 0x00 0x01 0x58 0x00 0x00
11:52:01 AM #147 CDCOPY -12 File TrackPFile.cpp, Line 271
68:46.62
11:52:01 AM #148 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 309362 to 309362
11:52:03 AM #149 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB8 0x99 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:04 AM #150 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF3480
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xB8 0x9D 0x00 0x00 0x01 0x58 0x00 0x00
11:52:04 AM #151 CDCOPY -12 File TrackPFile.cpp, Line 271
68:47.30
11:52:04 AM #152 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 309405 to 309405
11:52:41 AM #153 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x25 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:42 AM #154 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF6220
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x2E 0x00 0x00 0x01 0x58 0x00 0x00
11:52:42 AM #155 CDCOPY -12 File TrackPFile.cpp, Line 271
72:48.20
11:52:43 AM #156 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF6B40
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x2F 0x00 0x00 0x01 0x58 0x00 0x00
11:52:43 AM #157 CDCOPY -12 File TrackPFile.cpp, Line 271
72:48.21
11:52:43 AM #158 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327470 to 327471
11:52:44 AM #159 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x41 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:45 AM #160 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x44 0x00 0x00 0x01 0x58 0x00 0x00
11:52:45 AM #161 CDCOPY -12 File TrackPFile.cpp, Line 271
72:48.42
11:52:45 AM #162 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327492 to 327492
11:52:46 AM #163 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x5A 0x00 0x00 0x01 0x58 0x00 0x00
11:52:46 AM #164 CDCOPY -12 File TrackPFile.cpp, Line 271
72:48.64
11:52:46 AM #165 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327514 to 327514
11:52:47 AM #166 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x5D 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:48 AM #167 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x70 0x00 0x00 0x01 0x58 0x00 0x00
11:52:48 AM #168 CDCOPY -12 File TrackPFile.cpp, Line 271
72:49.11
11:52:48 AM #169 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327536 to 327536
11:52:49 AM #170 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x79 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:50 AM #171 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x86 0x00 0x00 0x01 0x58 0x00 0x00
11:52:50 AM #172 CDCOPY -12 File TrackPFile.cpp, Line 271
72:49.33
11:52:50 AM #173 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327558 to 327558
11:52:51 AM #174 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x95 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:52 AM #175 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0x9C 0x00 0x00 0x01 0x58 0x00 0x00
11:52:52 AM #176 CDCOPY -12 File TrackPFile.cpp, Line 271
72:49.55
11:52:52 AM #177 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327580 to 327580
11:52:53 AM #178 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0xB1 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:54 AM #179 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AF1920
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0xB2 0x00 0x00 0x01 0x58 0x00 0x00
11:52:54 AM #180 CDCOPY -12 File TrackPFile.cpp, Line 271
72:50.02
11:52:54 AM #181 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327602 to 327602
11:52:55 AM #182 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0xC8 0x00 0x00 0x01 0x58 0x00 0x00
11:52:55 AM #183 CDCOPY -12 File TrackPFile.cpp, Line 271
72:50.24
11:52:55 AM #184 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327624 to 327624
11:52:56 AM #185 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0xCD 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:57 AM #186 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0xDE 0x00 0x00 0x01 0x58 0x00 0x00
11:52:57 AM #187 CDCOPY -12 File TrackPFile.cpp, Line 271
72:50.46
11:52:57 AM #188 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327646 to 327646
11:52:58 AM #189 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0xE9 0x00 0x00 0x1C 0x58 0x00 0x00
11:52:59 AM #190 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x04 0xFF 0xF4 0x00 0x00 0x01 0x58 0x00 0x00
11:52:59 AM #191 CDCOPY -12 File TrackPFile.cpp, Line 271
72:50.68
11:52:59 AM #192 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327668 to 327668
11:53:00 AM #193 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x05 0x00 0x21 0x00 0x00 0x1C 0x58 0x00 0x00
11:53:01 AM #194 SCSI -1047 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AFCFA0
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x05 0x00 0x36 0x00 0x00 0x01 0x58 0x00 0x00
11:53:01 AM #195 CDCOPY -12 File TrackPFile.cpp, Line 271
72:51.59
11:53:01 AM #196 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327734 to 327734
11:53:02 AM #197 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x05 0x00 0x59 0x00 0x00 0x1C 0x58 0x00 0x00
11:53:03 AM #198 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x05 0x00 0x61 0x00 0x00 0x01 0x58 0x00 0x00
11:53:03 AM #199 CDCOPY -12 File TrackPFile.cpp, Line 271
72:52.27
11:53:03 AM #200 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327777 to 327777
11:53:04 AM #201 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x05 0x00 0x75 0x00 0x00 0x1C 0x58 0x00 0x00
11:53:05 AM #202 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x05 0x00 0x77 0x00 0x00 0x01 0x58 0x00 0x00
11:53:05 AM #203 CDCOPY -12 File TrackPFile.cpp, Line 271
72:52.49
11:53:05 AM #204 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327799 to 327799
11:53:06 AM #205 SCSI -1047 File Cdrdrv.cpp, Line 1435
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0x00 0x05 0x00 0x8D 0x00 0x00 0x01 0x58 0x00 0x00
11:53:06 AM #206 CDCOPY -12 File TrackPFile.cpp, Line 271
72:52.71
11:53:06 AM #207 Text 0 File TrackPFile.cpp, Line 259
Read error from LBA 327821 to 327821
11:53:17 AM #208 Text 0 File WriterStatus.cpp, Line 116
< Image Recorder > start writing Lead-Out at LBA 334393 (51A39h), lenght 0 blocks
11:53:17 AM #209 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
11:53:17 AM #210 Phase 161 File dlgbrnst.cpp, Line 1832
Burn process completed successfully with warnings
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/19/2004 10:11:48 PM
File 'Drivers\IdeChnDr.sys': Ver=2.3.0.2160, 10/01/2002, size=101431 bytes, created 10/15/2002 12:00:00 AM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
can i proceed with burning the image would it then run ?
- by tkin
