Old 26-08-2004, 03:41 PM   #1 (permalink)
Default Not able to view source in IE 6
When I click on view>source, I get a blank notepad window in return.
This happens with every Internet Explorer window.
Can any one tell me the solution plz? I have Windows XP and IE 6.
Get In Touch With ME!!!!
SID
sid_b6505 is offline
Old 28-08-2004, 10:57 PM   #2 (permalink)
Check ur default HTML editor under internet options.
Satan_Rulez is offline
Old 28-08-2004, 11:14 PM   #3 (permalink)
This is what i've been waiting for...
This is one of the major bugs in IE. Dude...check out that there IS an empty folder on tour desktop called "NOTEPAD". It will be hidden or even visible. Delete it. Then u can view the source.
Cheers!!! 8)
sUlPhUr|nE` is offline
Old 30-08-2004, 08:53 PM   #4 (permalink)
Default not able to view the source
hi...
there is no empty notepad document.
still can not view the source....
is there any registry problem?
help me!!
SID
Old 30-08-2004, 08:59 PM   #5 (permalink)
I am 100% sure that there is an empty NOTEPAD folder(Not a notepad Document) on your desktop. Go to Tools>folder Options> Unhide Protected System Files and Folders.
then you'll find a folder on your desktop..
Me really sure dude....
Old 30-08-2004, 10:37 PM   #6 (permalink)
abhishekkulkarni's Avatar
Why don't you just reinstall IE .
May the source be with you ..
abhishekkulkarni is offline
Old 31-08-2004, 12:30 PM   #7 (permalink)
Theres no need of it dude...Thats what I'm telling.
i'm 1000000% sure that there is an empty NOTEPAD "FOLDER". It cud also be with the System Attribute, so, ven if you tey to unhide hidden files you wont be able to c the folder until you unhide even the system files & folders.
Old 02-09-2004, 07:20 PM   #8 (permalink)
No text file is opening in notepad.
But these files can be opened from the open option in notepad.
SID
Old 02-09-2004, 10:26 PM   #9 (permalink)
Dude..
on your desktop, there is a FOLDER called notepad, NOT DOCUMENT. Delete the FOLDER CALLED NOTEPAD. There is no file or a document.
PHEW
Old 02-09-2004, 11:09 PM   #10 (permalink)
even i had this problems.. but it vanished automatically.. was gone .. no idea how it got repaired.. or wat ever..
vswizard is offline
Old 03-09-2004, 07:10 PM   #11 (permalink)
Sanchit's Avatar
Default It's simple
Just change your default HTML Editor settings in TOOLS/INTERNET OPTIONS/PROGRAMS.
It may also be a bug
Sanchit is offline
Old 03-09-2004, 10:01 PM   #12 (permalink)
Phew.....this is a bug...... nothing else..it is also not a virus....just take out the notepad folder & the job is done.
Old 03-09-2004, 11:59 PM   #13 (permalink)
@sid,
Look up this link below, it discusses the problem you face in great detail. and our friend sUlPhUr|nE 's advice included.
http://www.mredkj.com/tutorials/tips_ie.html
additionally, the article suggest looking up the MS KB:
# Q154168 Cannot View Source in Internet Explorer.
Solution: Notepad needs to be installed.
# Q179829 Cannot View HTML Source Code for Web Pages in Internet Explorer
Solution: Specify a valid path for the TMP environment variable.
# Q203592 Cannot View Source Code for Web Pages
Solution: Include the Change permission for the Cookies folder.
# Q306907 Source Code Is Not Displayed When You Click Source on the View Menu in Internet Explorer
Solution: Delete Temporary Internet files
sailendra is offline
Old 04-09-2004, 04:06 PM   #14 (permalink)
I told you!!
The guy who had da problem is out of order or what??? He is no where to be heard or seen
Old 05-09-2004, 10:49 PM   #15 (permalink)
lavan_joy's Avatar
Use opera.....or do what sUlPhUr|nE` said
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 06-09-2004, 12:16 AM   #16 (permalink)
Yepp! lavan's rite..use Opera..it dosent have any such bugs.
Old 09-09-2004, 08:45 PM   #17 (permalink)
Cheers!!! 8)
Waiting for it???
Were uwaiting for poor sid_b6505 for having problems.
I guess not.
Then why?
Old 09-09-2004, 09:49 PM   #18 (permalink)
Its not like that. I knew that atleast 1 person WILL have that problem. I was waiting for someone to ask. Thats all.
Chill man! 8)
Old 17-09-2004, 01:16 AM   #19 (permalink)
parthbarot's Avatar
that pag ei think was a diff page
can be PHP , ASP . or JSP .it can be so thst class file is required.
u can not see source for dynamic pages mostly.
but try sime diff things
my home page:----http://www.freeinfonet.tk
www.techlads.com
Paarth.
parthbarot is offline
- by tkin
