just check out ebay the site is full of them costs about Rs 600/- and the item claimes to be 15 in one reader.
15 in 1 Card Reader/Writer
Item Description
You're bidding on a brand new 15 in 1 USB 2.0, USB 1.1 card reader/writer. This nifty little unit will enable you to transfer your digital files between your computer and just about any flash media card available (CF, MD, SD, MMC, SM, MS, MS-PRO, MS-MAGIC-GATE, MS-DUO, XD, RS-MMC, mini-SD), and, because it is USB 2.0 ready, it will do so at lightning speed.
Features
USB bus powered device, no external power needed, plug & play for USB 1.1, USB 2.0. With up-stream data rate of 12MB/s
Perfect mate for digital camera, digital audio player, PDA, communcation devices, and other digital electronic devices with storage features.
Supports Windows 98, Windows 98SE, Windows 2000, Windows ME, Windows XP, Mac 8.6, 9.0+, 10.0+ or above.
Hot swappable and USB Mass Storage supported.
Package Contains
* Card Reader
* Drive CD
* USB Extension Cable
* User's Manual
**** happens
