Old 08-04-2008, 10:17 PM   #1 (permalink)
Exclamation SONY optical drives support help needed
i have sony's dvd writer dw-g120a bought 2-3 years back and it works perfectly well
i wanted to know if the dvd-region restrictions can be removed as i read somewhere on net that it can be done (i have used the 3-4changes allowed)
also, i was wondering why there is no official website of sony's optical drives even being the best???
also, my drive's tray cover has no company logo
(there are dvd, rw, compactdisk logos below the tray-cover)
is there something wrong or could it be that the dealer(seller from whom i bought it) changed the bezel(cover) to black to match with my pc???
plzzz reply soon
saurabhsun is offline
Old 08-04-2008, 11:09 PM   #2 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Default Re: SONY optical drives support help needed
The Sony DVD-RW which isn't having the Sony logo on the tray is actually the unboxed one ... u must have got it cheaper in comparison to the boxed version .. but don't worry , u can claim warranty from Sony for that .
Regarding changing dvd-region restrictions , i didn't understand ur query .. so plz be more specific !
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 08-04-2008, 11:17 PM   #3 (permalink)
i meant about region that:
there are 3-4 chances given to change the region code and i have used all of them and i cant change the code further for watching movies dvds set for other codes.......is it possible to make the drive region free????
i use dvd regionfree software and there is no problem but a permanent solution would be better
Old 09-04-2008, 09:16 AM   #4 (permalink)
TheSaint
NucleusKore's Avatar
For your drive see this
http://forum.rpc1.org/dl_firmware.php?download_id=2246
Also read this article
http://forum.rpc1.org/viewtopic.php?t=239
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
How to 2-3 optical drives Sridhar_Rao Hardware Q&A 9 21-11-2007 10:49 AM
Where are my Optical Drives? emailaatif786 Hardware Q&A 5 24-01-2007 02:06 PM
SATA Optical Drives ?? varun_ag QnA (read only) 12 28-04-2005 11:41 PM
Installing two Optical Drives sid_b6505 QnA (read only) 4 24-03-2005 09:11 AM
Lite-On Optical Drives Combination shyamthakkar QnA (read only) 9 28-10-2004 12:49 AM
- by tkin
