hi..
i hav 2.6ghr , 845original intel board, 256mb ram, samsung cd rom & a samsung combo. from last few days my combo is not burning cd's properly. i m using nero 6 . i m posting log file of failed process.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/28/2004 4:51:12 PM
Nero version: 6.6.0.0 (Nero Express)
Recorder: <SAMSUNG CDRW/DVD SM-352N>Version: TA01 - HA 1 TA 0 - 6.6.0.0
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SAMSUNG CDRW/DVD SM-352N>Version: TA01 - HA 1 TA 0 - 6.6.0.0
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV0802N atapi Port 0 ID 1 DMA: On
CdRomPeripheral : SAMSUNG CDRW/DVD SM-352N atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-ROM SC-152L atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
SAMSUNG CDRW/DVD SM-352N H: CDRom0
SAMSUNG CD-ROM SC-152L I: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 253MB (259888kB)
Free physical memory: 47MB (48240kB)
Memory in use : 81 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.4.2005
Video CD
3:37:51 PM #1 Text 0 File VCDDoc.cpp, Line 1350
VideoCD document burn settings
Compilation type : VCD
Menu : Enable
Picture in separate folder : TRUE
Folder name
ICTURES
Use CD-I : TRUE
CD-I configuration : CONTROLS=ALL
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
Encoding bitrate mode : User defined (kb/s)
3:37:51 PM #2 Phase 82 File dlgbrnst.cpp, Line 1861
Encoding video
3:37:51 PM #3 Text 0 File VCDCompilationImpl.cpp, Line 499
Using Nero Video Converter version 0.00
3:37:51 PM #4 Text 0 File AVIVCDFileItem.cpp, Line 882
Encoding G:\man in black 2\1\AVSEQ05.DAT to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\NERC.tmp
ScalingType: 0 Video: yes Audio: yes
File size: 23397740 bytes
Resolution: 352x288 25 Hz
Frames: 3282
3:37:51 PM #5 Text 0 File AVIVCDFileItem.cpp, Line 895
Playing time: 131.280000 s
Requested rate: 225 KB/s
iVideoRate=0
iAudioRate=32
Estimated size: 9846 blocks
3:38:21 PM #6 Text 0 File AVIVCDFileItem.cpp, Line 924
Encoding done
3:38:25 PM #7 Text 0 File VCDFileItem.cpp, Line 430
Actual size: 9870 blocks
3:38:25 PM #8 Text 0 File VCDFileItem.cpp, Line 434
The generated Video file is 0.999392 of the evaluated size
3:38:25 PM #9 Text 0 File AVIVCDFileItem.cpp, Line 882
Encoding G:\man in black 2\1\AVSEQ16.DAT to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\NERF.tmp
File size: 20528300 bytes
Frames: 2876
3:38:25 PM #10 Text 0 File AVIVCDFileItem.cpp, Line 895
Playing time: 115.040000 s
iVideoRate=0
iAudioRate=32
Estimated size: 8628 blocks
3:38:51 PM #11 Text 0 File AVIVCDFileItem.cpp, Line 924
Encoding done
3:38:55 PM #12 Text 0 File VCDFileItem.cpp, Line 430
Actual size: 8653 blocks
3:38:55 PM #13 Text 0 File VCDFileItem.cpp, Line 434
The generated Video file is 0.999422 of the evaluated size
3:38:55 PM #14 Text 0 File Isodoc.cpp, Line 6170
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 2 / XA
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
3:38:55 PM #15 Text 0 File VCDDoc.cpp, Line 2819
VCD options:
Create standard compliant CD: YES
Encoding resolution: NTSC
3:38:55 PM #16 Text 0 File Burncd.cpp, Line 2834
Super Link activated
3:38:55 PM #17 Text 0 File Reader.cpp, Line 127
Reader running
3:38:55 PM #18 Text 0 File Writer.cpp, Line 122
Writer SAMSUNG CDRW/DVD SM-352N running
3:38:55 PM #19 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
3:38:55 PM #20 ISO9660GEN -11 File geniso.cpp, Line 3286
3:38:55 PM #21 Text 0 File Burncd.cpp, Line 3119
Turn on Disc-at-once, using CD-R/RW media
3:38:56 PM #22 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 290419 ( 64:34.19)
3:38:56 PM #23 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO (enabled: CD)
3:38:56 PM #24 Text 0 File DlgWaitCD.cpp, Line 2310
Recorder: SAMSUNG CDRW/DVD SM-352N;
CDRW code: 00 97 17 01; OSJ entry from: Moser Baer India Limited
ATIP Data:
Special Info [hex] 1: E3 00 CF, 2: 61 11 01 (LI 97:17.01), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 24 2C AC, 2: 6C A4 34, 3: 04 D1 80
3:38:56 PM #25 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
3:38:56 PM #26 Text 0 File ThreadedTransferInterface.cpp, Line 844
Setup items (after recorder preparation)
0: TRM_DATA_MODE2_2336 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1614 (1614) = #1614/0:21.39
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 1614 blocks [SAMSUNG CDRW/DVD SM-352N]
1: TRM_DATA_MODE2_2336 (AVSEQ01)
original disc pos #0 + 489 (489) = #489/0:6.39
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 489 blocks [SAMSUNG CDRW/DVD SM-352N]
2: TRM_DATA_MODE2_2336 (AVSEQ02)
original disc pos #0 + 145598 (145598) = #145598/32:21.23
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 145598 blocks [SAMSUNG CDRW/DVD SM-352N]
3: TRM_DATA_MODE2_2336 (AVSEQ03)
original disc pos #0 + 714 (714) = #714/0:9.39
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 714 blocks [SAMSUNG CDRW/DVD SM-352N]
4: TRM_DATA_MODE2_2336 (AVSEQ04)
original disc pos #0 + 1259 (1259) = #1259/0:16.59
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 1259 blocks [SAMSUNG CDRW/DVD SM-352N]
5: TRM_DATA_MODE2_2336 (AVSEQ05)
original disc pos #0 + 9960 (9960) = #9960/2:12.60
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 9960 blocks [SAMSUNG CDRW/DVD SM-352N]
6: TRM_DATA_MODE2_2336 (AVSEQ06)
original disc pos #0 + 6795 (6795) = #6795/1:30.45
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 6795 blocks [SAMSUNG CDRW/DVD SM-352N]
7: TRM_DATA_MODE2_2336 (AVSEQ07)
original disc pos #0 + 9554 (9554) = #9554/2:7.29
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 9554 blocks [SAMSUNG CDRW/DVD SM-352N]
8: TRM_DATA_MODE2_2336 (AVSEQ08)
original disc pos #0 + 8772 (8772) = #8772/1:56.72
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 8772 blocks [SAMSUNG CDRW/DVD SM-352N]
9: TRM_DATA_MODE2_2336 (AVSEQ09)
original disc pos #0 + 8424 (8424) = #8424/1:52.24
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 8424 blocks [SAMSUNG CDRW/DVD SM-352N]
10: TRM_DATA_MODE2_2336 (AVSEQ10)
original disc pos #0 + 13441 (13441) = #13441/2:59.16
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 13441 blocks [SAMSUNG CDRW/DVD SM-352N]
11: TRM_DATA_MODE2_2336 (AVSEQ11)
original disc pos #0 + 6270 (6270) = #6270/1:23.45
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 6270 blocks [SAMSUNG CDRW/DVD SM-352N]
12: TRM_DATA_MODE2_2336 (AVSEQ12)
original disc pos #0 + 7916 (7916) = #7916/1:45.41
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 7916 blocks [SAMSUNG CDRW/DVD SM-352N]
13: TRM_DATA_MODE2_2336 (AVSEQ13)
original disc pos #0 + 11609 (11609) = #11609/2:34.59
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 11609 blocks [SAMSUNG CDRW/DVD SM-352N]
14: TRM_DATA_MODE2_2336 (AVSEQ14)
original disc pos #0 + 9346 (9346) = #9346/2:4.46
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 9346 blocks [SAMSUNG CDRW/DVD SM-352N]
15: TRM_DATA_MODE2_2336 (AVSEQ15)
original disc pos #0 + 22024 (22024) = #22024/4:53.49
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 22024 blocks [SAMSUNG CDRW/DVD SM-352N]
16: TRM_DATA_MODE2_2336 (AVSEQ16)
original disc pos #0 + 8743 (8743) = #8743/1:56.43
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 8743 blocks [SAMSUNG CDRW/DVD SM-352N]
17: TRM_DATA_MODE2_2336 (AVSEQ17)
original disc pos #0 + 10469 (10469) = #10469/2:19.44
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 10469 blocks [SAMSUNG CDRW/DVD SM-352N]
18: TRM_DATA_MODE2_2336 (AVSEQ18)
original disc pos #0 + 4723 (4723) = #4723/1:2.73
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 4723 blocks [SAMSUNG CDRW/DVD SM-352N]
3:38:56 PM #27 Text 0 File ThreadedTransferInterface.cpp, Line 1045
Prepare recorder [SAMSUNG CDRW/DVD SM-352N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x20; Session Closed, disc fixated
Tracks 1 to 19:
1: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 0 352800 4148928, ISRC ""
2: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 4148928 4501728 5651856, ISRC ""
3: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 5651856 6004656 348451152, ISRC ""
4: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 348451152 348803952 350483280, ISRC ""
5: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 350483280 350836080 353797248, ISRC ""
6: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 353797248 354150048 377575968, ISRC ""
7: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 377575968 377928768 393910608, ISRC ""
8: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 393910608 394263408 416734416, ISRC ""
9: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 416734416 417087216 437718960, ISRC ""
10: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 437718960 438071760 457885008, ISRC ""
11: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 457885008 458237808 489851040, ISRC ""
12: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 489851040 490203840 504950880, ISRC ""
13: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 504950880 505303680 523922112, ISRC ""
14: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 523922112 524274912 551579280, ISRC ""
15: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 551579280 551932080 573913872, ISRC ""
16: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 573913872 574266672 626067120, ISRC ""
17: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 626067120 626419920 646983456, ISRC ""
18: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 646983456 647336256 671959344, ISRC ""
19: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 671959344 672312144 683420640, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1614 | 2 | 0 | 0x00 | 0x41
1764 | 2 | 1 | 0x00 | 0x41
2253 | 3 | 0 | 0x00 | 0x41
2403 | 3 | 1 | 0x00 | 0x41
148001 | 4 | 0 | 0x00 | 0x41
148151 | 4 | 1 | 0x00 | 0x41
148865 | 5 | 0 | 0x00 | 0x41
149015 | 5 | 1 | 0x00 | 0x41
150274 | 6 | 0 | 0x00 | 0x41
150424 | 6 | 1 | 0x00 | 0x41
160384 | 7 | 0 | 0x00 | 0x41
160534 | 7 | 1 | 0x00 | 0x41
167329 | 8 | 0 | 0x00 | 0x41
167479 | 8 | 1 | 0x00 | 0x41
177033 | 9 | 0 | 0x00 | 0x41
177183 | 9 | 1 | 0x00 | 0x41
185955 | 10 | 0 | 0x00 | 0x41
186105 | 10 | 1 | 0x00 | 0x41
194529 | 11 | 0 | 0x00 | 0x41
194679 | 11 | 1 | 0x00 | 0x41
208120 | 12 | 0 | 0x00 | 0x41
208270 | 12 | 1 | 0x00 | 0x41
214540 | 13 | 0 | 0x00 | 0x41
214690 | 13 | 1 | 0x00 | 0x41
222606 | 14 | 0 | 0x00 | 0x41
222756 | 14 | 1 | 0x00 | 0x41
234365 | 15 | 0 | 0x00 | 0x41
234515 | 15 | 1 | 0x00 | 0x41
243861 | 16 | 0 | 0x00 | 0x41
244011 | 16 | 1 | 0x00 | 0x41
266035 | 17 | 0 | 0x00 | 0x41
266185 | 17 | 1 | 0x00 | 0x41
274928 | 18 | 0 | 0x00 | 0x41
275078 | 18 | 1 | 0x00 | 0x41
285547 | 19 | 0 | 0x00 | 0x41
285697 | 19 | 1 | 0x00 | 0x41
290420 | lead-out | 1 | 0x00 | 0x41
3:38:56 PM #28 Phase 73 File dlgbrnst.cpp, Line 1861
Preparing items
3:38:57 PM #29 Phase 24 File dlgbrnst.cpp, Line 1861
Caching of files started
3:38:58 PM #30 Text 0 File Burncd.cpp, Line 4135
Cache writing successful.
3:38:58 PM #31 Phase 25 File dlgbrnst.cpp, Line 1861
Caching of files completed
3:38:58 PM #32 Phase 36 File dlgbrnst.cpp, Line 1861
Burn process started at 10x (1,500 KB/s)
3:38:58 PM #33 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:38:58 PM #34 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #1764
3:38:58 PM #35 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #2403
3:38:58 PM #36 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #148151
3:38:58 PM #37 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #149015
3:38:58 PM #38 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #150424
3:38:58 PM #39 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #160534
3:38:58 PM #40 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #167479
3:38:58 PM #41 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #177183
3:38:58 PM #42 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #186105
3:38:58 PM #43 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #194679
3:38:58 PM #44 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #208270
3:38:58 PM #45 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #214690
3:38:58 PM #46 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #222756
3:38:58 PM #47 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #234515
3:38:58 PM #48 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #244011
3:38:58 PM #49 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #266185
3:38:58 PM #50 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #275078
3:38:58 PM #51 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #285697
3:38:58 PM #52 Text 0 File Mmc.cpp, Line 15894
StartDAO : CD-Text - Off
3:38:58 PM #53 Text 0 File Mmc.cpp, Line 20542
Set BUFE: Super Link -> ON
3:38:58 PM #54 Text 0 File Mmc.cpp, Line 16181
CueData, Len=320
41 00 00 34 00 00 00 00
41 01 00 21 00 00 00 00
41 01 01 21 00 00 02 00
41 02 00 21 00 00 17 27
41 02 01 21 00 00 19 27
41 03 00 21 00 00 20 03
41 03 01 21 00 00 22 03
41 04 00 21 00 20 37 1a
41 04 01 21 00 20 39 1a
41 05 00 21 00 21 06 41
41 05 01 21 00 21 08 41
41 06 00 21 00 21 19 31
41 06 01 21 00 21 1b 31
41 07 00 21 00 23 28 22
41 07 01 21 00 23 2a 22
41 08 00 21 00 25 0d 04
41 08 01 21 00 25 0f 04
41 09 00 21 00 27 16 21
41 09 01 21 00 27 18 21
41 0a 00 21 00 29 15 1e
41 0a 01 21 00 29 17 1e
41 0b 00 21 00 2b 0f 36
41 0b 01 21 00 2b 11 36
41 0c 00 21 00 2e 10 46
41 0c 01 21 00 2e 12 46
41 0d 00 21 00 2f 2a 28
41 0d 01 21 00 2f 2c 28
41 0e 00 21 00 31 1e 06
41 0e 01 21 00 31 20 06
41 0f 00 21 00 34 06 41
41 0f 01 21 00 34 08 41
41 10 00 21 00 36 0d 24
41 10 01 21 00 36 0f 24
41 11 00 21 00 3b 09 0a
41 11 01 21 00 3b 0b 0a
41 12 00 21 00 3d 07 35
41 12 01 21 00 3d 09 35
41 13 00 21 00 3f 1d 16
41 13 01 21 00 3f 1f 16
41 aa 01 34 00 40 22 14
3:40:40 PM #55 SCSI -1135 File Cdrdrv.cpp, Line 1429
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x07FF0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0x1C 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
3:40:40 PM #56 CDR -1135 File Writer.cpp, Line 311
Write error
3:40:41 PM #57 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
3:40:41 PM #58 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
3:40:41 PM #59 Text 0 File dlgbrnst.cpp, Line 1719
Set remaining time: 0:00,000 (0ms) -> OK
3:40:41 PM #60 Phase 38 File dlgbrnst.cpp, Line 1861
Burn process failed at 10x (1,500 KB/s)
3:40:41 PM #61 Text 0 File AVIVCDFileItem.cpp, Line 988
Temporary file C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\NERC.tmp deleted
3:40:41 PM #62 Text 0 File AVIVCDFileItem.cpp, Line 988
Temporary file C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\NERF.tmp deleted
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 10/28/2003 3:32:00 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 11:29:44 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
plese tell me, is my combo is defected or any softwre problem. well this drive working well 1 week before.
reply as soon as possible,.
thanks in advance.
