Old 04-04-2008, 02:50 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Red face Locking Folders On External HDD
Hello Guys,
I m having one Seagate 650GB SATA II Firewire External HDD.....now i want to lock some folders on it containing confidential data !
I want a software which enables locking up of folder even when i connect it to a different PC ... when i try to access it , password shud be asked for !
Thnx
BlackBerry7100g.
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 04-04-2008, 02:56 PM   #2 (permalink)
unni's Avatar
Default Re: Locking Folders On External HDD
Best option, in my opinion is to use TrueCrypt to encypt the data.
unni is offline
Old 04-04-2008, 06:15 PM   #3 (permalink)
^^He will have to install truecrypt on each pc through which he wants to access these encrypted files which may not be feasible. Password protection to ZIP archive would be a better option than that
ThinkFree is offline
Old 04-04-2008, 08:33 PM   #4 (permalink)
^^ exactly...but one more thing , i don't want it to convert it to an archive ... i just want that the folder shud be accessible with just typing the password , and then the contents are easily visible ( just like the windows logon ...
One more thing if the above can't be done , is there any way out i can make my folder hidden as soon as the HDD is disconnected from my PC and plugged into another PC , and whenever i need to access that folder , i can make it visible !
Old 05-04-2008, 09:41 AM   #5 (permalink)
hansraj's Avatar
Guys hold.................... who says that if u want to use truecrypt then one has to install truecrypt on each pc.
if u have truecrypt isntalled then check the feature Tools>Traveller Disk Set Up and go ahead with it. Truecrypt gets installed with the required files in the removable storage and u can now carry it to any PC with windows. Now u need not require the truecrypt installed on that pc and truecrypt will run standalone to encrypt/decrypt anywhere u want.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 05-04-2008, 10:11 AM   #6 (permalink)
unni's Avatar
That's 100% correct. TrueCrypt is completely portable. The only catch is you need to have admin rights on the PC you want to run TrueCrypt.
unni is offline
Old 05-04-2008, 06:19 PM   #7 (permalink)
Any other way out other than true crypt ?
Locking folders without commercial softwares. redhat Tutorials 17 07-01-2007 11:42 AM
locking drive and folders from registry!!! kin.vachhani Software Q&A 8 27-12-2006 06:22 PM
locking CD Ishan QnA (read only) 4 05-05-2006 01:07 AM
Anybody know softies for locking multiple folders. Freewares Charley QnA (read only) 2 09-09-2005 04:19 PM
Locking kumarn_2004 QnA (read only) 3 19-06-2005 09:54 PM
- by tkin
