Re: image of the machine to cd or dvd
U also have the option of using Norton ghost 12 or 14. Its better than acronis because of its feature of "LIghtsout restore" in which u will start getting an option of restore the ghost image at the time of every boot once u enable it. This means if u r system at anytime is bootable but doesnt start properly or some serious virus/malware activity and u want to restore back to a saved image in that case u dont even require the bootable disk.(This will kind of make u independent of the Norton Recovery bootable disk). Rest of the features are more or less same.
But before using any one of the above two i suggest that get ur system formatted again and keep ur system files in a partition of 20 GB which is good enough. Rest of the partitions can be as per ur choice.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
