minimalistic bhai,
thanks for detailing me the procedure
i knew some1 out here is very genius
thanks a lot bhai
johny
I got a minor directX problem please reply if u can help
I got
p4 2.8 gh HT
intel915 motherboard
512 MB ram
200gb SATA
80gb PATA
My OS is WinXp with services pack 2 integrated
i got all my drivers n other things in place
PROBLEM
i got direct X 9.0b installed
i downloaded directX9.0c from microsoft
but after installing it i was not able to run the programs for which i needed the dX9.0c
So i diagnosed it and in dxdiag command ifound the diectx file qasf.dll was having some problem.
i even tried searching the qasf.dll and replacing it with the latest downloaded version of the same file.
I had updated my drivers for graphics as well.
NOTHING HELPED.
I know u will do it easily.
HELP ME BRO
Johny 8)
