Old 02-04-2008, 12:02 PM   #1 (permalink)
NBC(Next Bill Candinate)
100.dx's Avatar
Default wht is this means plssssss help
My Order Detail Orderid 982539 Order Type Plan Change Plan Name Home UL 900 Order Status Open
hello freinds this is from my bsnl portal id
what is this means
is i m running on homeul 900 plan???
what is this means order status-open
100.dx is offline
Old 02-04-2008, 01:43 PM   #2 (permalink)
100.dx's Avatar
Default Re: wht is this means plssssss help
hey where u gone guyzzz
pls help me dude
wht tht means?
is i m running on home900 plan?
100.dx is offline
Old 02-04-2008, 02:09 PM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
256 Kbps / 32 KBps
Gigacore is offline
Old 02-04-2008, 03:32 PM   #4 (permalink)
Order Status Open
what is this means
Hi ,
to find your BB plan ..
login to your dataone portal..
then go to service records
there you will find your" plan"
Regards
imageek is offline
wat does this error means and how can i get rid of this... Manshahia Software Q&A 2 15-01-2008 07:13 PM
vps-what does it means? kerthivasan QnA (read only) 4 26-02-2007 03:54 PM
What does this means? hluachawngthu QnA (read only) 1 11-06-2006 10:51 PM
Want: VHS to CD. Means: Suggest!! Dumbledore Hardware Q&A 5 13-03-2006 05:21 AM
What this term means? cyberdude QnA (read only) 3 19-02-2006 09:07 PM
- by tkin
