phpBB Group announces the release of phpBB 2.0.14, the "We know we are (not) furry" edition. This release addresses some bugfixes as well as
fixing some minor non-critical security issues.
It is urged to all phpBB users to update as soon as possible.
This download is available
here
The changelog (contained within this release) is as follows:
- Hardened author and keyword search a bit to not allow very server
intensive searches
- Fixed full path disclosure in bad word parsing
- Resetting complete userdata array in session code if authentication
fails
- Fixed bug in moderator control panel where certain parameters could
lead to an "error creating new session" sql error
- Fixed bug in session code where empty page ids could lead to an
- Fixed html handling in signatures if html is turned off globally
- Fixed install.php problem with PHP5 register_long_arrays option
turned off
- Fixed potential issues with styling system
- Added correct class to login_body template file
- Removed file db/oracle.php from package.
- Removed version number from message body page in /admin (if user is
not an admin) - mikelbeck
- Fixed case-sensitivity issues in postgres7.php - R45
Source:
http://www.phpbb.com/index.php
