Old 01-04-2008, 12:28 PM   #1 (permalink)
raksrules's Avatar
Default Are these files necessary in 'C' drive ???
The C drive in my office PC is running out of space and i am getting the Low disk space message now and then. Deleting temp and temp internet files doesn't help much. I saw these folders in the windows directory. They are all hidden. Are these necessary or can i delete them safely.
$NtUninstallKB873339$
$NtUninstallKB917159$
and so on occupying nearly 1 Gb of space.
Please suggest. Also if there are any other places from where i can delete unnecessary files to reclaim the space.
raksrules is offline
Old 01-04-2008, 01:32 PM   #2 (permalink)
PhotonAttack
DigitalDude's Avatar
Default Re: Are these files necessary in 'C' drive ???
its just the temp files incase you want to revert any service packs and windows updates installed by windows.
you can just delete them.... if you dont plan to uninstall windows updates and service packs...
I just delete them
_
In a time of universal deceit, telling the truth is a revolutionary act - George Orwell
|| तमसो मा ज्योतिर्गमय ||
DigitalDude is offline
Old 01-04-2008, 02:52 PM   #3 (permalink)
raksrules's Avatar
Thanks a lot !!!
Old 01-04-2008, 02:52 PM   #4 (permalink)
Cool G5's Avatar
Use Ccleaner which will clean Temp files,browsers cache & other unwanted files.
Cool G5 is offline
Old 01-04-2008, 07:31 PM   #5 (permalink)
Hi
u can try one more thing,go to properties for that drive,in disk cleanup(>>more options) there is one button to remove all but the most recently made restore point.You can try that if you want,
Genrally, restore points can take up a lot of disk space,when clogged up for a long period of time
regards
imageek is offline
Old 01-04-2008, 07:54 PM   #6 (permalink)
Kiran.dks's Avatar
Originally Posted by imageek View Post
Hi
regards
Simple way to have a control over it is by allocating some fixed disk space to it. Like I have alloted 1GB. It will never pass that mark!
Kiran Kumar R
Kiran.dks is offline
Old 01-04-2008, 08:08 PM   #7 (permalink)
So how do you clear it when you want ??
Regards
imageek is offline
recovery of files from my crashed hard drive thoma.anish QnA (read only) 9 04-06-2009 07:51 PM
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
do bin and iso files have larger files sizes than it's contents??? tango_cash Software Q&A 5 29-02-2008 08:29 PM
copying files become slow in my usb drive thecreativeboy Hardware Q&A 4 30-06-2007 05:02 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
- by tkin
