Old 15-04-2005, 04:30 PM   #1 (permalink)
sourav's Avatar
Default Autorun Gone... CD
I'm using a Windows XP Pro with Ububtu (Linux). My question is that when I use Windows CD's having autorun don't start. So, I reinstalled Windows but after some days it again stopped showing autorun. It doesn't show CD's label. What should I do to get reed of it. Plz Hlp
[edit:techno] please post your queries in the QnA forums and not in the tutorials forum
sourav is offline
Old 15-04-2005, 06:17 PM   #2 (permalink)
Default try this...
open my computer-->right click ur cdrom drive icon----->click properties-->click on autorun tab--> and play around with the settings...
this might help u...
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 17-04-2005, 09:40 AM   #3 (permalink)
sourav's Avatar
Default Re: try this...
I know and I have done this. It shows autorun is enabled.
sourav is offline
Old 17-04-2005, 10:57 AM   #4 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
By any chance do you use TweakUI?
Also this is the command to disable the same ...Check if doign the opposite enables it back
1) Click Start, Run and enter GPEDIT.MSC
2) Go to Computer Configuration, Administrative Templates, System.
3) Locate the entry for Turn autoplay off and modify it as you desire.
Hope this helps
FilledVoid is offline
Old 02-05-2005, 10:27 AM   #5 (permalink)
sourav's Avatar
Hope this helps
No, I don't use tweak UI
sourav is offline
Old 02-05-2005, 10:29 AM   #6 (permalink)
sourav's Avatar
Hope this helps
No, I don't use tweak UI and i was also not using
sourav is offline
- by tkin
