| Forum |
#1 (permalink) | |
i have got a big problem here .. 1. in the first part the digit people asked to type in some command in command prompt ... i typed in EXACTLY what they had written(of course i gave the right CD-ROM drive letter)... but as i press enter the following is displayed Quote:
2. the second solution give is to open notpad files and type in and save them ... there, should i replace "%SYSTEM ROOT%" with the location of the system32 folder on my computer ? please help me ... i am expecting ur answer soon saurya
Physics-Philosophy-Saurya |
#3 (permalink) |
Let me find page 82 .... done!
(1) i think the digit people forgot u to tell that u should put ur WIndows XP CD in the CD Drive. if u already 've a copy of xp setup in the harddisk replace the path with that. (2) %SYSTEMROOT% is environment variable. just test by echoing it (in the command prompt : echo %SYSTEMROOT%) so u dont need to replace anything. (btw, if the first works, then no need of 2nd)
Quitters Never Win & Winners Never Quit! |
#4 (permalink) | |
Fresh Stock Since 2005
#6 (permalink) |
digit asked to replace three files : autoexec.nt command.com config.nt ...i found some of these in the repair folder of windows ...can i replace them from there ?
by the way what is this problem actually ... i mean what caused it ...
#7 (permalink) |
thanks everybody the problem is solved ... u wont belive the autoexec.nt file was not in the system32 folder ... so i put it there and it was solved ... THANKs whol heartedly
| Bookmarks |
| Display Modes | |
