Old 15-04-2005, 01:49 PM   #1 (permalink)
Default Help with tcpsvcs.exe!!!
Hi,
I have installed tune-up utilities 2004. After tweaking my pc whenever I connect to internet, a service named tcpsvcs.exe uses 40 - 85% of my processor constantly. It slows down my PC.
I've also set default settings of PC using tune-up utilities, but nothing changes. Can anyone help me with this
Delta is offline
Old 15-04-2005, 02:20 PM   #2 (permalink)
tcpsvcs - tcpsvcs.exe - Process Information
Process File: tcpsvcs or tcpsvcs.exe
Process Name: TCP/IP Services
Description:
tcpsvcs.exe is a part of Microsoft Windows networking components. This essential system process is initiated when the computer uses special TCP/IP networking services such as DHCP, Simple TCP and print services. This program is important for the stable and secure running of your computer and should not be terminated.
Info :http://www.liutilities.com/products/...brary/tcpsvcs/
Very strange,I would anyways suggest a anti-spyware scan with spybot & MS anti-spyware.
www.Oobertech.net
digen is offline
Old 15-04-2005, 02:29 PM   #3 (permalink)
I've already done with microsoft antispyware, nothin happened
Delta is offline
Old 15-04-2005, 07:02 PM   #4 (permalink)
swatkat's Avatar
Where is the file located? A trojan called EggHead uses the same file name.
More info here
Dowanload CCleaner andi install it. Boot in SAFE mode. Open CCLeaner and click "Options", here UNCHECK the option "Delete only temp files older than 48 hours". Then click "Run Cleaner", and delete any file it finds.
http://www.ccleaner.com/
Download TrojanHunter Trial and install it. Run "Full Scan" and delete all the entries it may find.
http://www.trojanhunter.com/
http://swatrant.blogspot.com/
swatkat is offline
Old 16-04-2005, 10:43 PM   #5 (permalink)
Thanx Braniacs for ur infos!!! It was Egghead in my pc.
Delta is offline
Old 16-04-2005, 11:17 PM   #6 (permalink)
Fresh Stock Since 2005
Are you sure that came from TuneUp Utils.............
khattam_ is offline
Old 17-04-2005, 06:05 PM   #7 (permalink)
No!!! I haven't said that it was came from Tuneup Utils. I experienced load on my pc after tweaking my pc.
Delta is offline
Old 17-04-2005, 06:34 PM   #8 (permalink)
swatkat's Avatar
Is the CPU usage lowered now? Did TrojanHunter forund that trojan?
swatkat is offline
Old 17-04-2005, 07:15 PM   #9 (permalink)
Yeh!! everything is working fine after removing that.
Delta is offline
- by tkin
