Which data management application will help me.....?
i have a shop of foot wears... am looking to manage its stock by my pc.... i heard Tally is quite tough... so can any one tell me any other application.. which would be easy to handle.
some one suggess oracle...... but i dont know any programming
Re: Which data management application will help me.....?
go for MySql or Oracle or there are mny of the Business Application softwares availble through which you can even customize your application program as well look for such one.
I suggest better use Tally 9.
It is excellent for you. If u implement with due care, u will be able to generate any type of reports e.g. salesmanwise, companywise, sizewise, fast moving etc.
