How to edit or delete a scene from a movie (AVI) file?
I have a movie which is of AVI format. I need to crop certain scenes i.e. delete certain scenes from the movies? How is this possible? I tried Virtual Dub but after I use it the resultant output is either patch or the audio sync is lost. Is there any software which can help me do this? Preferably free ware but if its really good and its paid doesn't matter. I heard something called AVS video converter! But not sure.
Re: How to edit or delete a scene from a movie (AVI) file?
^ ^ he already mentioned he used virtualdub.
as far your question goes, I assume you cut the video alone at different intermediate stages for loss of your audio sync. I think you have to separate out your audio track as well and use an audio editor to cut the audio tracks pertaining to that time line and then join them again using virtual dub or any other software (windows movie maker??)
