Old 28-03-2008, 07:59 AM   #1 (permalink)
Default Getting this error msg.
Whenever I start my PC, a error is shown which reads "C/WINDOWS/System32/BerasJatah.exe was not found.....Make sure you typed the name correctly''. I googled but it did't help to kill this problem. This has made my PC damn slow. But to do.
gigyaster is offline
Old 28-03-2008, 08:25 AM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Getting this error msg.
It's a Trojan
Go to http://housecall.trendmicro.com and scan your PC
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 28-03-2008, 10:18 AM   #3 (permalink)
This indicates that your antivirus has deleted the trojan. But as it had inserted its entry into Windows registry, Windows tries to load that deleted file.
You try to search the entry in registry and delete it carefully. Better way you disable it through msconfig.
bhansalibg is offline
Old 28-03-2008, 11:21 AM   #4 (permalink)
Am not that good in registry, i mean i don't want to take a risk. If any one of you can provide the steps, I know its difficult to locate the entry but still.
Old 28-03-2008, 11:22 AM   #5 (permalink)
go to run and type -> msconfig (enter), in the windows which pops open, go to startup and uncheck the entry (the exe file you were referring to).
legolas is offline
Old 28-03-2008, 11:27 AM   #6 (permalink)
^^ Well i did this. But when the PC restarts thn the entry itself becames check. I think I have to type "regedit" and than.................plz say.
Old 28-03-2008, 11:31 AM   #7 (permalink)
In that case, you have not removed the Trojan. Usually Trojan removal softwares are more effective than antivirus for Trojans. Try using Trojan remover software
legolas is offline
Old 28-03-2008, 11:37 AM   #8 (permalink)
Well... is it a free software. Are u sure it will remove the torjan. Ok, m downloading it.
Old 28-03-2008, 12:06 PM   #9 (permalink)
It has helped to remove trojans in my friend's laptop more than twice. I remember it being trialware at that time. Now its a freeware. Doesn't matter if its freeware. Don't underestimate programs coz they are freeware Nod32 is free i guess? Linux is free Give it a try.
legolas is offline
Old 28-03-2008, 05:13 PM   #10 (permalink)
My Macafee(orginal) did't detect any torjan nor thr Sypbot S&D could find any. Thrs no such entry (BerasJatah.exe) on the starup tab.(msconfig). Now what to do.
Old 28-03-2008, 05:41 PM   #11 (permalink)
TheSaint
Did you try what I suggested^
Old 28-03-2008, 08:38 PM   #12 (permalink)
Yeah i did it. But than it did't detect any torjan.
How to find out the meaning of an Error Message or Error Code. anandk Software Q&A 7 27-06-2010 05:30 PM
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
- by tkin
