View Poll Results: Do you use 64-bit OS?
Yes, everything is working properly. 1 11.11%
Yes, but some apps dont work properly. Those apps are... 3 33.33%
I used it before but reverted back to 32; I'll tell you why... 2 22.22%
None of above; I'll tell you why... 3 33.33%
Voters: 9. You may not vote on this poll
Old 25-03-2008, 08:10 PM   #1 (permalink)
The real Bond
yogeshm.007's Avatar
Lightbulb 32-bit vs 64-bit
Hi, i'm thinking of upgrading my 4-yr old system and was just wondering if 64-bit software is common or not and wanted to know your experience with 64-bit software...
yogeshm.007 is offline
Old 25-03-2008, 09:19 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: 32-bit vs 64-bit
Im 64 bit, on both Windows and Linux
kalpik is offline
Old 25-03-2008, 11:24 PM   #3 (permalink)
i have a 32 bit system, but i don't see a point why 64 bit should have compatibility issues with softwares. Many of my friends have 64 bit systems. You can definitely go for it.
legolas is offline
Old 26-03-2008, 12:02 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Upgrade to 64 bits.......
Top 10 benefits of Windows XP Professional x64 Edition
ravi_9793 is offline
Old 26-03-2008, 12:14 AM   #5 (permalink)
clmlbx's Avatar
I used 64 bit but some(rare to me )softwares just denied to install on it (yes, x64)that emulates 32 bit .................so i was unable to use that softwares....that was some months ago .......looking to this thread will again try xp 64 bit ..but as now I am also using vista x64 .
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 26-03-2008, 11:14 AM   #6 (permalink)
The real Bond
Originally Posted by ravi_9793 View Post
Thanks, but my concern is that whether most popular apps (on windows) are available on 64-bit as well or they run well in 32-bit compatibility mode. I mostly use Linux so I can migrate to x86-64 OS without any theoretical problem, but my brother and sister use the PC via Windows. Brother mainly use MS Office, Nokia PC Suit and of course Firefox. Sister is presently into Radio and use various sound/image editing software with video editing coming next...
Old 26-03-2008, 11:46 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
cant say about particular software compatibility ...but most software runs easily.
Old 26-03-2008, 01:28 PM   #8 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
driver compability , i never found my webcam,cellphone, and many drivers in 64 bits
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
- by gforz
