Old 25-03-2008, 10:26 AM   #1 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Thumbs down MegaUpload Toolbar - How Safe ?
A few of my friends have installed megaupload toolbar to download files from megaupload.com. We generally do bandwidth sharing when it comes to downloading a large number of files. But I have not installed the megaupload toolbar, because I heard somewhere that its unsafe.
So I want to confirm things here, and its urgent. How safe is the megaupload toolbar for Internet Explorer ? (There is no way I am installing sh!t on my lovely firefox) Can I undo the changes made due to its installation by removing it ? Is there any way to completely purge the megaupload toolbar ? Are there any licence agreement terms that try to mess with the user ?
For the reference:
I hate shareware trial licences
I hate licences that restrict the stuff I am allowed to do with the software to the point of outrageousness
I hate adware
I hate nagware
I hate spyware
and I hate any other type of malware or badware.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 25-03-2008, 10:33 AM   #2 (permalink)
Think Zen.
ray|raven's Avatar
Default Re: MegaUpload Toolbar - How Safe ?
^It installs Alexa Toolbar , which is spyware.
http://www.symantec.com/security_res...062410-3624-99
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 25-03-2008, 10:39 AM   #3 (permalink)
slugger's Avatar
if you dont wan2 go through the entire EULa then it is good ida to run it through EULAlyzer™
slugger is offline
Old 25-03-2008, 10:49 AM   #4 (permalink)
The Smaller Bang
and how do I disable alexa installation ?
PS: wasn't some guy posting in the tech news section recently about digit forum going up in alexa rankings ? Are both these alexas the same ?
Old 25-03-2008, 10:59 AM   #5 (permalink)
kumarmohit's Avatar
It does not install Alexa toolbar, It IS Alexa toolbar. Just with a rebranding.
kumarmohit is offline
Old 25-03-2008, 11:02 AM   #6 (permalink)
The Smaller Bang
then is there a way to install the alexa toolbar in IE for Linux ?
I heard there is a way to install IE7 in linux, which is easily purged with the usual routine.
I am now concidering installing this toolbar inside it and ditching it after I am finished using the download service.
Is it possible ?
Old 25-03-2008, 11:06 AM   #7 (permalink)
Ethan_Hunt's Avatar
Well I had just installed this bloody thing recently & it messed up some browser settings for Firefox on my PC.I had get a music video very urgently & for that was forced to install this darn thing.After uninstalling the software it still had it's Toolbar option in my Mozilla broswer.I unchecked it to remove it but the enrty is still there.
From here on,I noticed some wierd changes in my broswer.Whenever I would loose a connection to the internet it would load up with a message "Internet explorer could not load this page" & has some yahoo toolbar link at the bottom.This didn't used to happen before.It would just have default Firefox screen where it would say the internet is not connected click "Try Again" to check the webpage again.But this is one strange thing which has been bugging me.I have noticed no Alexia stuff on my PC.Have run Spybot S&D numerous times & no traces found yet.Same with Kaspersky.
My recommendation is don't use it unless very urgent.
V for Vendetta
Ethan_Hunt is offline
Old 25-03-2008, 11:08 AM   #8 (permalink)
Think Zen.
ray|raven's Avatar
@MetalHead
Dude, spyware is spyware anywhere,
Why would you want to install it even after you know it's spyware,
Get another file hoster for crying out loud.
Old 25-03-2008, 11:12 AM   #9 (permalink)
The Smaller Bang
I think
this solution is supposed to work, as it comes from symantec.
But my friends never told me that they experience such problems with it. They said it never interfeared with anything they did in their browsers. How can it be true ? Is it because this problem was only found on an older version of the toolbar ?
Old 25-03-2008, 11:13 AM   #10 (permalink)
Proud to be Linux
abhinandh's Avatar
Please don't install that piece of s***.
It completely crippled my pc.
better host files at www.mediafire.com which is way better.
http://abhinandh.com
abhinandh is offline
Old 25-03-2008, 11:52 AM   #11 (permalink)
The Smaller Bang
the problem is that nearly every file is present in www.rapidshare.com and www.megaupload.com and both of them are hypocrytic in nature. zShare and zUpload are much better too. So what can I do ? Its monopoly all over again. The same reason people use Windows over Solaris is applicable here. Windows has a monopoly and hence a huge array of software is available for it, but Solaris is vastly unknown and hence has little software for it and hence has a relatively small userbase.
Tell me one site with links for mediafire files. You will hardly find any. Whereas rapidshare and megaupload links are featured everywhere, even on THIS forum.
Old 25-03-2008, 11:56 AM   #12 (permalink)
Think Zen.
ray|raven's Avatar
^Even I have had this problem,most sites do have rapidshare or megaupload links.
Rapidshare is somewhat better, you dont need to install crap to download stuff.
Personally, I try and get alternative download links to rapidshare/megaupload links.
If all fails,there's always P2P.
Old 25-03-2008, 12:21 PM   #13 (permalink)
The Smaller Bang
not most sites. Its ALL SITES
Good Point. If you know which server to use for downloading to get max speed, you can manage a smooth 180 kbps on RS.
please PM me
P2P... Damn 40 kbps. I hate slow speeds.
trick for megaupload....no alexa toolbar mukul Tutorials 59 26-04-2009 04:11 PM
Megaupload Help Plz.............. Serious_Sam Tutorials 5 06-11-2007 03:37 AM
Download easily from Megaupload without Toolbar using a new APP imdbest Tutorials 13 27-05-2007 05:25 PM
Megaupload help please Kushneel QnA (read only) 5 27-08-2006 02:30 PM
- by gforz
