Old 23-03-2008, 07:57 PM   #1 (permalink)
Smile How to change Default "My Documents" location?
Hello friends!
Can someone please tell me how to change the location of "My Documents" and "Program Files" in Windows XP other than the default location as provided by the operating system ?
Also,any website where such things about XP can be easily read would be helpful too.
Thanking you in advance.
arnold is offline
Old 23-03-2008, 08:08 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: How to change Default "My Documents" location?
To change My Documents location:
1) Right Click on My Documents
2) Click Properties
3) And enter your desired location in target.
To change Program Files location:
Go here
Third Eye is online now
Old 23-03-2008, 08:09 PM   #3 (permalink)
To change the location for "Program Files" you'll have to reinstall the OS after customizing it with Nlite. And to change the location for "My Documents" Click Start > Right Click on My Documents > Properties > Click the button "Move" and select the Drive where you want it to be.
'Veni, Vidi, Velcro\' - I came, I saw, I stuck around.
hyde is offline
Old 23-03-2008, 08:36 PM   #4 (permalink)
Kiran.dks's Avatar
Check this link:
http://www.kiran-world.com/move-my-d...her-partition/
Kiran Kumar R
Kiran.dks is offline
Old 23-03-2008, 10:15 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
You can refer to mine article also for this:
http://www.techhunt.org/node/115
ravi_9793 is offline
Old 23-03-2008, 10:24 PM   #6 (permalink)
Thank you everyone for comming up with the tricks!
Third Eye thank you specially for the trick to change the Prog Files default location,I was really looking for that one;.
I was just wondering,can the contents of the previous "Program Files" be moved to the new location without hampering the working of the previously installed programs, just like moving the contents of "My Documents" is done smoothly.
arnold is offline
Old 25-03-2008, 12:46 PM   #7 (permalink)
Unhappy Re: How to change Default "My Documents" location?
Go here
I followed the same as is stated in the above link. But,the problem is,"Outlook Express" in not starting at all untill I am getting back to my previous default setting and then rebooting. So,I just want to know,changing the "Program Files" would never allow "Outlook Express" to work smoothly? If yes,then how to do it?
arnold is offline
Old 25-03-2008, 01:02 PM   #8 (permalink)
gooby pls
Third Eye's Avatar
^ 1) Go to Program Files
2) Open Outlook Express
3) Right Click on msimn and create shortcut.
4) Cut and paste the shortcut in Desktop.
5) You are done!
Old 25-03-2008, 01:11 PM   #9 (permalink)
5) You are done!
Thanks for the reply. But,as soon as I change my "Program Files" location,Outlook Express cannot be started at all;The error I am getting is the following :-
"OE cannot be started.The application was unable to open OE message store.Your computer may be out of memory or your disk is full.Contact MS for further assistance.[Ox8007007E,126].
OE could not be started because MSOE.DLL could not be initialized, OE may not be installed correctly."
But,I have more than 7 GB in both the partition,and it's working fine as soon as I change back to my default "Program Files" location and reboot.
Please help.
arnold is offline
Old 25-03-2008, 01:15 PM   #10 (permalink)
gooby pls
Third Eye's Avatar
Just keep the location of Program Files to default. Do not change it because such problems will come.
Is there a way to change the default location of My Pictures/My Music folders in XP? nuke_32 Software Q&A 2 14-03-2008 04:08 PM
Change The Default Location For Installing Apps ashish_patel Tutorials 4 09-01-2008 11:15 PM
change default documents folder in vista iMav Software Q&A 1 05-06-2007 12:29 AM
making "d" drive default location for softwares ??? rajasekharan Software Q&A 5 17-03-2007 11:43 AM
make "Add to playist" as my default option for mp3 file sridatta Software Q&A 7 30-08-2006 07:45 PM
- by gforz
