| Forum |
#1 (permalink) |
Hope you guys like it. ![]() ![]() ![]() ![]() My Total Setup was as following - Asus A8N-E Motherboard AMD Athlon 64 3000+ [939 Pin,Winchester Core] 256 x 2 Generic Hynix DDR RAM modules based on Hynix D43 chips 40GB Seagate Cuda 300 Watt KPPL PSU XFX Gefore 6200TC 256 MB Grafix card Gigabyte 52X CD-RW Cooling for CPU - Stock with AS5 applied Cooling For Chipset - Stock with AS5 applied |
#2 (permalink) |
Hey darky that are pretty impressive figures.
And that RAM overclocking i am stunned and the BW provided is absolutely awesome. Did you get a new mobo what happened to ur a8n sli. Which Ram's are you using because i am shocked at the extent they have overclocked. Are they normal Hynix DDR 400 PC3200 RAM's how much did they cost you Single DDR 400 Chip 256MB. What are these "Hynix D43 chips" is it something special. Will i be able to overclock it to same frequencies using 512MB module of the same company. The Ram overclocking has impressed me a lot , can these figures be reached on a ASUS A8N Sli. Is this the XFX 6200TC 256MB card ![]() How much did it cost you & can you let me know the 3DMarks 2003 & 2005 score with that card. Please let me know i am eager to know.
Overclock Me. Overvolt Me. AMD Me. |
#4 (permalink) |
nice one darklord. Man i can never get my CAS timings to go so low. Right now its a 6-3-3-2.5 and I cant get it lower than that...And how does one increase the frequency by the way ?
AMD 64 3500+ Venice DFI Lan Party Ultra-D 2* 512 MB PdP Memory with 2-2-5L timings XFX 7900GT 256 MB Card |
#5 (permalink) | |||||||
I still have the A8N SLI Deluxe. Quote:
Yes it is the normal Hynix DDR400. I got 4 x 256 MB Sticks and each cost me 1700/- Quote:
I tried OC'ing Only the RAM on A8N SLI and i achieved 295.7MHz on it. Quote:
I havent tried benchmarking it,will let you know asap.The card cost me 4k. Quote:
#6 (permalink) | |
hynix ram reaching 297.5 i am not able to believe. Was this 1:1 overclocking on the A8N Sli. What verson of asus a8n Sli bios are you using. Hey darky when ever i visit pune i will suerly drop at ur place if u dont mind.
#7 (permalink) | ||
I am using 1006 Final release BIOS. Also default Vdimm is 2.6V i had to up it to 3.0V to reach there.I had to relax the timings too. Yeah sure, you can drop in any time,you are most welcome. Looking forward to your visit. |
#8 (permalink) |
When you OCed it to 295.7 Mhz on the A8N Sli
can you let me know a few exact figures. - What are the exact ram timings all 4 - Was the command rate at 2T or 1T - What sort of memory BW did you get in Sandra - did you run memtest86 to check ram stability if yes for how long. ------------------------- - Can you give the exact codename of the Hynix DDR400 PC3200 256MB Ram and what can it be for 512MB module , or can u give me a site link where i can find all hynix ram modules info in detail with there codenames. - Do all Hynix Rams use the D43 Chip or only specific. - How to identify if the Hynix Ram has D43 Chips. ASUS A8N Sli actually has a problem with 1:1 overclocking over 250Mhz with Dual Channel DDR Rams at 1T Command Rate it has to be changed to 2T to go above 250Mhz 1:1. This ASUS problem has not yet been solved even in the latest 1007 Bios. Lastly where did you get Mushkin DDR Ram from and how much for it. Are OCZ DDR400 PC3200 Plat Rev 2 Rams available here , because they overclock like hell. Please dont feel like i am asking too many questions but i like to get my doubts cleared.
#9 (permalink) | ||||||
![]() It was obviously @ 2T [Kept it to Auto i guess] I didnt run any benchmarks as it was a suicide screenshot. No i didnt run memtest86. Also i know that its running in single channel and @ 2t,but i was trying this for the first time with that RAM,so was a bit cautious.Now that i am confident that it OC'es well,i will try dual channel and try to run some benchies. Quote:
There are D43 chips in 512 MB sticks also. No there are numerous Hynix Models.The ones that OC well are D43 & D5 The model No. on the Dram IC,there is a long model no.at the end there is a "-" in between and then there are 2 letters,which is either "D43" or "D5" or something else. Quote:
I got 2 sticks each of 256 MB.I purchased it from him for 6k. Quote:
#10 (permalink) | |
Do let me know about how much do you overclock with Dual Channel DDR400 Hynix on A8N Sli.
Can you overclock with 1T and let me know how much does the Hynix Ram reach please i mean the max HTT Speed. So i can get a good idea of its max htt speed. Quote:
reached 250Mhz 1:1 at 1T. Ram used OCZ Plat Rev2 PC3200 DDR400 do confirm the exact model number on the Hynix DDR400 Chips having the D43. Amoung D43 & D5 which overclocks better.
#11 (permalink) |
hey darklord ,
can u plz tell me how to overclock the ram and if possible my mobo and procosser.my system is INTEL 865 GBF (original) P-4 2.4 GHZ 40 GB Hdd 256 MB DDR 333 MHZ RAM(non-hynix) geforcefx 5200 128 Mb ram
Windows XP Pro Service Pack 2 build=2600 Mobo- MSI PM8M-V GenuineIntel Intel(R) Pentium(R) 4 CPU 2.40GHzRAM : Installed : 512 * 2 MB DDR RAM (TRANSCEND) XFX FX5200 128 MB |
#13 (permalink) |
Awoesome overclocking Darklord , BTW , how long was the machine stable ? Because i dont see any special cooler in the system , or a high end PSU.
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK |
#14 (permalink) |
I see that the RAM is running at almost 280Mhz DDR ie at 560Mhz that is nearly impossible for a normal Hynix Ram.
Even transcend Rams fail 2 acheive such an exhaustive Overclcock U r really lucky Darklord Hav u verified ur overclock darklord??? if no get it verified and post it on http://www.x86-secret.com I hope u r really very lucky 2 get a gr8 overclock without using any specific cooling GR8 job Darklord U r really the lord of DARKNESS |
| Bookmarks |
| Display Modes | |
