Old 23-03-2008, 05:16 PM   #1 (permalink)
Eager to learn.
power_8383's Avatar
Default Hard thinking about Hard Disk
Hi guys,
I'm planning to buy a new external hard disk for my system. (Intel 845GLVA)
My budget is upto Rs.3,000/- only, so plz dont suggest me more than 320 GB HDD.
Please tell me which is the best HDD available in this budget.
Some things Man was never meant to know.
For everything else, there's Google.
power_8383 is offline
Old 23-03-2008, 05:27 PM   #2 (permalink)
napster007's Avatar
Default Re: Hard thinking about Hard Disk
u'll get all info here
i'll suggest you go for the WD. it's been very faithfull to me.
napster007 is offline
Old 24-03-2008, 05:59 AM   #3 (permalink)
Eager to learn.
power_8383's Avatar
@ Napster
I've seen all the sites bro.
I want the reviews (From Indian Websites) or the opinions by the experienced users, who are using external hard disks.
Old 24-03-2008, 07:00 AM   #4 (permalink)
I suggest Maxter or Lacie. Both are extremely good. Lacie is sleek external hardisk which doesn't require power supply ( costlier for same GB) where as Maxter I got 500 GB for abt 95€ (when euro was < 60). so, you could get Maxter in your budget for your size I hope. good luck.
legolas is offline
Old 25-03-2008, 12:08 PM   #5 (permalink)
Eager to learn.
power_8383's Avatar
Any other suggestions ?
Old 25-03-2008, 04:12 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
imo, get a normal desktop hdd + an external casing .... cheap & more space ..
... W H O T ...
ax3 is offline
Old 25-03-2008, 04:34 PM   #7 (permalink)
Eager to learn.
power_8383's Avatar
what is the price of external case ?
Old 25-03-2008, 04:36 PM   #8 (permalink)
Think Zen.
ray|raven's Avatar
^Abt ~500 , varies with brand i guess.
Get a laptop hard disk and external casing, you should get em both within 3k
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 25-03-2008, 04:40 PM   #9 (permalink)
Eager to learn.
power_8383's Avatar
I've bought Seagate 160GB IDE HDD for Rs.2200\- ( My motherboard doesnt support SATA )
Can I use this HDD too as external HDD ?
Old 25-03-2008, 04:42 PM   #10 (permalink)
Think Zen.
ray|raven's Avatar
^I've seen casings for laptop disks only,but i guess u can get them for normal ones too.
But, AFAIK, you need to have external power supply to use hdd through usb.
And AFAICR, i read somewhere saying laptop hdd's dont need it.
Old 25-03-2008, 05:14 PM   #11 (permalink)
Eager to learn.
power_8383's Avatar
Ok, thnx for info
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
XP on USB Hard Disk sachin_kothari Hardware Q&A 3 31-10-2006 10:41 PM
how to add two hard disk ravi_9793 QnA (read only) 3 23-07-2006 06:53 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by gforz
