Old 23-03-2008, 04:02 PM   #1 (permalink)
DeXt0R
Posts: n/a
Default Two Users - But only 1 PC.
I got a dual core 3.2 GHZ.
and a XFX 8600 GT gfx card.
Is it possible to run two different users on the same CPU?
Let me put it this way...
Is it possible to have two users working at the same time from the same PC?
Like 2 monitors, 2 mice, 2 keyboards.
I have heard its possible on linux but, i want windows.
Old 23-03-2008, 04:09 PM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: Two Users - But only 1 PC.
^^You can connect 2 monitors to your rig. But im not sure if you can connect 2 keyboard, mice, etc.
http://twitter.com/akshayms
nvidia is offline
Old 23-03-2008, 04:15 PM   #3 (permalink)
slugger's Avatar
you can do it with a reverse kvm swiitch
slugger is offline
Old 23-03-2008, 04:15 PM   #4 (permalink)
DeXt0R
Posts: n/a
Thanks for the fast reply, but i know i can connect two monitors... ^.^
I need to have separate desktops on both the monitors...
Each with its different mouse and keyboard.
@slugger?
whats a kvm switch?
how much it costs and where can i get it?
Googling to find out what it is...
Old 23-03-2008, 04:22 PM   #5 (permalink)
slugger's Avatar
Originally Posted by DeXt0R View Post
@slugger?
whats a kvm switch?
not a kvm switch - reverse kvm switch
if ur GPU does not support multiple monitor then you could buy this USB device that lets you attach another monitor @1024*768 with 16-bit color
slugger is offline
Old 23-03-2008, 04:25 PM   #6 (permalink)
DeXt0R
Posts: n/a
Umm yea...
But will i be able to have two seperate working desktops on both the monitors?
Like one user will be using "application A" and another will be using "application B"
Old 23-03-2008, 04:26 PM   #7 (permalink)
-----ATi-----
nvidia's Avatar
@DeXt0R:
http://en.wikipedia.org/wiki/KVM_switch
nvidia is offline
Old 23-03-2008, 04:29 PM   #8 (permalink)
slugger's Avatar
a KVM switch is used to control 2 computers from 1 keyboard/mouse/monitor
a reverss KVM switch will allow mulitple keyboard/mouse/monitor to control on computer
u migth even want to considder a dirt cheap thin client for your doual core comp
slugger is offline
Old 23-03-2008, 04:40 PM   #9 (permalink)
DeXt0R
Posts: n/a
Umm i just dont want to coltrol the "Virtual Mouse" (Which can be seen on the screen) with two physical mice...
I need to work on seperate application...
Can i do that with reverse kvm switch?
Any MPD users here? ray|raven Open Source 4 10-03-2008 03:35 PM
Hotmail to offer POP3 to Hotmail Plus users, to normal hotmail users later alsiladka Technology News 27 25-09-2007 12:49 PM
any n70 users plz help! mandar5 Mobiles and Tablets 9 21-06-2007 09:45 PM
What 64 Bit users are doing? .. Using 32 Bit or 64 Bit OS? rollcage QnA (read only) 27 09-03-2006 07:21 AM
3ds Max users or Maya users mad_gundam QnA (read only) 35 21-12-2004 04:26 PM
- by gforz
