Old 23-03-2008, 01:56 PM   #1 (permalink)
ajayritik's Avatar
Default What does AC3 6 Channels mean?
I tried searching for the term but did'nt get an exact meaning of the term? If at all I want to play a DVD Rip on my Home Theater which is the best DVD rip that I Should look for? I borrowed some DVD Rips from my friend but I wasnt getting very good quality sound output on my Home Theater? Is it because it was a 700 MB rip? I also came across this terme AC3 6 Channels. So apart from the actual DVD-R that we get what are the other formats that though they are lesser in size we will get good quality especially audio? Please help!
ajayritik is online now
Old 23-03-2008, 07:22 PM   #2 (permalink)
ajayritik's Avatar
Default Re: What does AC3 6 Channels mean?
Can someone please help me withe some information about the above?
Old 23-03-2008, 09:03 PM   #3 (permalink)
AC3 is an audio filter. When it says, it comes with 6 channels, it means that you would get the best out of audio even if you use a 6 channel speaker, as in a 6.1. But, to my knowledge if you are using a stereo, you would not experience any difference, if not a tint. It certainly would be better than say other lower quality audios and because its AC3, you can use AC3 filter to boost your volume, surround and stuffs and make it better. I hope this helped a little?
legolas is offline
Old 23-03-2008, 09:07 PM   #4 (permalink)
ajayritik's Avatar
Dude the information that you gave was definitely useful I wanted to check would it make a difference when I play it on my Home Theater as compared to playing it on a PC. Coz I primarily I'm looking to play it on my home theater. Will it be good or you think its really not worth it. I heard somewhere in the forum that even after compressing you may get almost same quality in sound .
Old 23-03-2008, 09:14 PM   #5 (permalink)
If you have a home theater, at least 5 channels (i presume), yes, AC3 6 channel audio will definitely have a better effect than a dual channel audio which will be the same as how you hear in a stereo. Go ahead. Its worth it
legolas is offline
Old 23-03-2008, 09:22 PM   #6 (permalink)
ajayritik's Avatar
Thanks a million dude! You made my Easter! Have a good nite and a great week ahead!
Are there any medical IRC channels? phreak0ut QnA (read only) 3 31-03-2007 08:24 PM
Which TV channels on EDGE Charley Mobiles and Tablets 5 09-07-2005 08:35 PM
- by gforz
