Old 13-04-2005, 11:27 PM   #1 (permalink)
mario_pant's Avatar
Default uninstalling OS??
hey i recently installed WinXP home... on the same drive as my winXP home SP2 was installed.... actualli i did it as the earlier windows had crshed... now i have some how revived my earlier windows so i want to uninstall\delete the other windows.... what is the way to do it....
there are to window:
1. C:\WINDOWS
2. C:\WINXP
whe ni start my computer i get a MultiOS boot screen... and i have to choose between WINXP HOME & WINXP HOME....
so i want this to go away to....
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 14-04-2005, 12:50 AM   #2 (permalink)
You can just delete the windows folder which you dont need, but the programs you have installed on that windows wont be deleted.
to remove the multiOS boot screen, type "boot.ini" in start-run and remove the windows you do not need.
I think this may work
girishtare is offline
Old 14-04-2005, 01:09 AM   #3 (permalink)
mario_pant's Avatar
ummm.... are u sure.... cause i dont want any more fatal errors....
Old 14-04-2005, 01:13 AM   #4 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
One should never install 2 OS on same drives as it can be very dangerous. You have mixed 2 OS completely.
Also the windows u want to remove, u should remove its folder by booting into the other one. No gurantee that all of xp can be removed.
You can also check out http://www.petri.co.il/uninstall_windows_xp.htm for removing any of the required xp.
But remember never install 2 os on same drive especially xp, 2000, nt or 2003.
navjotjsingh is offline
Old 14-04-2005, 02:04 PM   #5 (permalink)
Tux
Posts: n/a
Yeaqh. Even avoid WinXp and 98/me.
Try to install XP on ntfs.
Old 14-04-2005, 10:22 PM   #6 (permalink)
Fresh Stock Since 2005
No fatal errors........... Just delete the WinXP(or whichever) folder and edit the Boot.ini file...........
Your boot.ini should look like this after editing it:
[boot loader]
timeout=0
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINXP="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
khattam_ is offline
Old 14-04-2005, 10:41 PM   #7 (permalink)
[boot loader]
timeout=0
[operating systems]
Agree!!!! 8) Perfect Solution!!
Delta is offline
