Re: how to join multiple iso files in one dvd
from the reply qwertymaniac gave above, if I were you, I would check the fan sites to check for the availability of the utility or post a thread in the fan forum to get to know the possibility which would be more apt, from the response given above.
Even if you suggest us to help you find it, you haven't given the name of your game. Either ways, I recommend you to do what I had mentioned above. Good luck.
