strange!!!
opera simply closes the browser when i try to open it in 1 and the link address is also dodgy
IE shud not b popping up if you are not working with it?
is it happenenin obly when you accessing a particular site or is it happenin for all sites
if it is the latter then get your comp ascanned with a good AV like KLAV, NOD32 or sumthin
if it is the former then i suggest you dont visit the link
