Old 25-08-2004, 08:27 PM   #1 (permalink)
Default hdd problem
i got a new maxtor 160gb hard drive. i tried to put it with my celeron 500 intel 810mb pc. it is detecting it but it is asking for a dynamic drive overlay some kinda thing. can anyone suggest me how do go about it and i want to installed 98 and xp in dual booting and then how do i do it. someone please help me.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 25-08-2004, 09:10 PM   #2 (permalink)
I don't know anything about the hardiskproblem you have but I can tell you how to do a dual boot.
First see that you have atleast two partitions.
second Install windows 98 first!!!
Third after installing windows 98 install win XP in a drive other then that you installed win 98 in.
For example if U install win 98 in the c: drive Install win XP in the d: drive
The dual boot option you will get automatically when Booting.
Also see that you install win 98 FIRST and then win XP
HAPPY COMPUTING
netcracker is offline
Old 26-08-2004, 01:28 AM   #3 (permalink)
Looks like your mobo doesn't support this high capacity HDD. Try flashing your BIOS to the latest version which you can find at the motherboard's manufacturer site. This should definitely solve your problem.
Moin is offline
- by gforz
