Old 13-04-2005, 10:23 PM   #1 (permalink)
Default Bluetooth in pc?
how do i come to know whether my motherboard has bluetooth or not.
my vendor had said it has, but since at that time i didnt require it (nor did i know what it was) I didnt bother much.
but now i have an n-gage and wanna tranfer stuff to my cell without using usb cable.
btw, how do i come to know what motherboard make and model is mine?
I know its MSI, but dont know model no and all.
ANy ideas?
Thanx and cheers!
geekhead83 is offline
Old 13-04-2005, 10:33 PM   #2 (permalink)
why need title?
bharathbala2003's Avatar
get Fresh Diagnose from freshdevices.com.. install it.. and when u open it ull know all details starting from ur Motherboard to the OS ur using.. u can either download it from its site.. or get it from this month DIGIT CD..
bharathbala2003 is offline
Old 14-04-2005, 12:35 AM   #3 (permalink)
man.
just do one thing..
get ur motherboard software cd.. install Widcomm software from it.. (if you have bluetooth onboard then it must be with its driver that is widcomm) . and then after installing that u will get it.
u can also find it before installation, look of "SiW" in Device Manager .. if that hardware is there then u have bluetooth !
Ricky is offline
Old 14-04-2005, 10:59 PM   #4 (permalink)
ok....ill try both. is widcomm the only bluetooth device maker/provider ?
Old 15-04-2005, 10:36 PM   #5 (permalink)
there are only 2 major bluetooth stack provider.. one is BlueSoleil and other is widcomm ..
There are other stacks also available but mature one are only above.
Ricky is offline
Old 16-04-2005, 02:56 AM   #6 (permalink)
i've installed fresh diagnose and found that my motherboard is MSI kt4vl ms-6712 (phew).
on the following page, it says bluetooth pin header, bluetooth ready.
http://www.firingsquad.com/hw/127/MS...20/?viewdesc=1
now, it doesnt mention widcomm or anything of that sort.
so any ideas, on what i have to do to get bluetooth enabled on this mobo?
Old 16-04-2005, 03:27 AM   #7 (permalink)
aadipa's Avatar
a little google lead me to this
http://www.msi.com.tw/html/service/t...c_bt/page2.htm
btw i have same mobo and usb bluetooth dongle is much better than the setup involving bluetooth header, as u can take the dongle with u and plug in to any pc having usb port.
btw the info is given in ur mobo Quick User's Guide at pg 2-21
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 17-04-2005, 05:56 PM   #8 (permalink)
junk.. widcomm software works for almost every bluetooth thingi
Ricky is offline
Old 18-04-2005, 12:27 AM   #9 (permalink)
how much does that dongle cost? around 1k?
thanx for the informative post though @aadipa.
and now that uve mentioned that u have the same mobo, how do gmaes run on it? also depends on the graphics card u have (have a gefroce 2mmx)... just asking though.
- by gforz
