Old 13-04-2005, 09:50 PM   #1 (permalink)
Default Outlook Macro Location ?
I have created a macro in Outlook 2003 to save the Outlook folder contents to a folder in harddisk.
Now I want to share this macro with everybody by placing it in my website for download.
Can anybody tell me how to export this macro and also how to import this macro in Outlook ?
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 13-04-2005, 11:34 PM   #2 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Can't it be exported using Office Outlook's inbuild VB editor... ??
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 14-04-2005, 12:23 AM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. Try this ..
Run Outlook ..
Press Alt F8
Now Select the Macro you wanna export ..
Click on Edit
Now in the Visual Basic Editor,
Click on
File > Export ..
Save as a .BAS file ..
Later you can Import like this too ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 14-04-2005, 10:30 AM   #4 (permalink)
Outlook or Visual Basic Editor don't have the feature of exporting the macro.
So the only way according to Microsoft is to copy the project VbaProject.OTM located at [drive]:\Documents and Settings\[user]\Application Data\Microsoft\Outlook and place it some were else. Then rename it and distribute the OTM file.
Source: Microsoft
Kannan.
Kannan.
Binary Bits
Kannan is offline
- by gforz
