Old 20-03-2008, 08:27 PM   #1 (permalink)
Default how to lock desktop so no files saved on desktop
I am a poor organizer & have a bad habit of doing too many things (I am trying to improve) all together.
What I do is that anything useful I just drag it from FF3 to the dektop/save images & webpages to desktop & within few days I cant find my own saved data.
I have decided its time to organize myself & I mean it seriously so I am looking a way to lock the desktop so no file or shortcut can be placed there.
I want clean desktop with just aqua toolbar showing my program shortcuts & few frequently needed folders. Once I lock it it should not let me save anything on the desktop.
Few cybercafe have this method implemented so its indeed possible but do we need regedit or any software for doing this.
Hope you can help me in this.
ranjan2001 is offline
Old 20-03-2008, 09:44 PM   #2 (permalink)
slugger's Avatar
Default Re: how to lock desktop so no files saved on desktop
do you want to totally prevent saving to the desktop or you wont mind if the saved files are redirected to some non-visible folder
if it is the latter then you could enable folder redirection through group policy editor
though it is ment to redirect files to a folder on a remote computer
i guess if you enter the name of your own local computer then it would be redirected internally
slugger is offline
Old 20-03-2008, 10:39 PM   #3 (permalink)
vista__n00b's Avatar
1) Start --> Run --> gpedit.msc
2) user configuration --> administrative templates --> Desktop --> Hide and disable all items on the desktop --> enabled
vista__n00b is offline
Old 20-03-2008, 11:09 PM   #4 (permalink)
slugger's Avatar
if ur c: drive an NTFS partition, then you can just deny the right to modify the desktop folder. so all that is there can only be modified by a user with admin previalges
but of course u got 2 cre8 a user with diminished previlages fo this to work
AFAIK enabling this will noly hide the icons from the desktop
will not prevent you from transferring files to the desktop
slugger is offline
Old 20-03-2008, 11:36 PM   #5 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Check this out -
Local Computer Policy -> User configuration -> Administrative Templates -> Desktop -> Active Desktop.
Enable or disable whatever settings you want to as you please.
techtronic is offline
Old 20-03-2008, 11:46 PM   #6 (permalink)
If I can do the redirection (I didn't know that) that solves my purpose. Tell me how to & where to do the setting for the redirection.
Thanks
Originally Posted by techtronic View Post
Check this out -
When I open active desktop as per ur suggestion, I see "prohibit adding items" thats what I was looking for but now I have got Slugger suggestion to redirect to another internal folder, I would like to do that so even I drag any shortcut to desktop it will be saved in another folder which I can have access via tool bar.
Vista sidebar has something called magic folder does it do the same thing?
Old 20-03-2008, 11:47 PM   #7 (permalink)
slugger's Avatar
Using Folder Redirection
the server is called Test220
changed the link
slugger is offline
Old 20-03-2008, 11:53 PM   #8 (permalink)
Thanks I think that should work I will try that & will let you know.
Old 22-03-2008, 08:32 PM   #9 (permalink)
slugger's Avatar
did u try Belvedere Automated File Manager
shud offer you much more options in file redirection and much easier 2
slugger is offline
HHD & CD locking software? Anindya Software Q&A 9 22-03-2007 06:12 PM
sugg. software locking/hiding folder/partition portable hdd? It_is_Andrew Software Q&A 6 20-02-2006 02:45 PM
mobile locking software Raaza Mobiles and Tablets 1 22-10-2005 09:23 AM
Software to know who's locking Ports alib_i Software Q&A 8 28-06-2005 04:28 PM
folder locking software andy oza Software Q&A 6 06-04-2005 02:48 PM
- by gforz
