Hey Bro just download and install Real Player 11
it even adds a button to Youtube video screen so that you can directly download and save in your computer at the same time it does nt save in FLV format....and those downloaded files can be played only n only in real player 11 as far as i know..!!!
Make sure that you uninstall the previous versions of Real Player before you install Real Player 11....
Hope it may work for you
http://www.realplayer.com.au/freerp11.html?&rsrc=rp_au
check out the link to download....!!
