Old 13-04-2005, 11:50 AM   #1 (permalink)
Default buying a new pc ...
my old pc just fried and i wanna buy (assemble) a new pc. Should i go in for a motherboard without PCI-express or should i wait. Please give some config recomendations.
megacoolxs is offline
Old 13-04-2005, 01:37 PM   #2 (permalink)
ferrarif50's Avatar
If you are going for an Intel inside solution, then opt for a PCI-E mobo , but u need to shell out a lot for the graphics card. If u want AMD, then u only have nVidia nForce PCI-E motherboard, which is not yet avlble in India.
I would suggest you to go for an AMD Sempron processor based PC.
Look at some back issues of Digit , where there is a head to head comparison of AMD and Intel, along with suggestions for best solution with PCI-E
Hope this helps you.
My time machine will take you one hour into the future in only sixty minutes!
ferrarif50 is offline
Old 13-04-2005, 06:43 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
yes go in for PCI slots.. also id recomend Athalon and not Sempron.. but it all depends on your budget finally..
bharathbala2003 is offline
Old 13-04-2005, 08:38 PM   #4 (permalink)
Going for PCI-E is a good decision but the graphics card will be very expensive a(around 16k for a 128 MB). I wouldnt recomend u the PCI-E if u r not a gamer like me. But if u can wait until the price fall then u shud go for PCI-E.
Sankalp is offline
Old 13-04-2005, 10:00 PM   #5 (permalink)
frm where did u get that info????
buddy he can easily get a gfx card on PCI-E architecture easily within 10k...infact will recommend 6600 non GT 256MB for around 8.5 k frm delhi...
hey Sankalp pls post the prices for which ur 100% sure....
grinning_devil is offline
