Old 17-03-2008, 02:25 PM   #1 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Unhappy Help needed with Personal Website and Blog Designing
I have decided to build my website in the following 10 days in which I am free, as I have nothing else to do. The problem is that I am a HTML and CSS n00b and I still haven't learnt Python. Please solve the following problems of mine :
Website Building Software
1. I need a software to build it via WYSWIG and it must be really easy to use
2. I must be able to use that software in Ubuntu.
3. The software should be preferably made from QT, Python, Java, GTK2+, Perl or Ruby(in that order).
4. The software should have available tutorials for easy use
Webhosting
1. I already have a google pages account
2. I am thinking of going for paid hosting
3. I can Spare Rs. 350/- max for one year
Blog
1. The blog must be easy to edit/use
2. I like blogger and have an account
3. But I want to be able to catogarise posts, which I am unable to do in Blogger
4. Willing to try out wordpress
Will I be able to make both the blog and webiste within the same domain and intergrated into each other ?
I also need some advice on where to start and how to proceed.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 17-03-2008, 02:27 PM   #2 (permalink)
Think Zen.
ray|raven's Avatar
Default Re: Help needed with Personal Website and Blog Designing
Kompozer : http://www.kompozer.net/
That should work for designing web sites.
But still , if you want the best, go for Dreamweaver on wine.
It runs pretty well.
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 17-03-2008, 02:32 PM   #3 (permalink)
The Smaller Bang
how do I install it ?
my compiler is screwed, so no point trying to compile it.
I did not find it by doing sudo apt-get install kompozer.
Old 17-03-2008, 02:34 PM   #4 (permalink)
Think Zen.
ray|raven's Avatar
^Should be on the repos ,
Anyways here's a link : http://kent.dl.sourceforge.net/sourc....7.10-i386.deb
Btw, what do you mean by a "screwed" compiler?
Old 17-03-2008, 02:41 PM   #5 (permalink)
The Smaller Bang
got deb...
and my compiler don't compile well. only small software manage to get built.
need to wait for hardy to start kompiling.
Old 17-03-2008, 02:43 PM   #6 (permalink)
Unmountable Boot Volume
Cyrus_the_virus's Avatar
@metalhead, like always, you can get the lowest priced hosting from me. Only 149! If you really want it, then please do purchase before 31st as prices might not be the same afterwards.
250MB Space + 2.5GB Transfer for Rs12/month!!!
Webhosting for Rs12/month!!
http://www.thinkdigit.com/forum/showthread.php?t=74717
http://www.outpowerhosting.com
Cyrus_the_virus is offline
Old 17-03-2008, 02:45 PM   #7 (permalink)
Think Zen.
ray|raven's Avatar
Eh? Whats Hardy got to do with compiling?
Just make sure you got build essential and stuff.
And compiling errors dont mean compiler problem , they could also mean , dependencies are missing.
Ubuntu seperates dev files , so if you have say pidgin installed , doesnt mean you have pidgin development files installed too.
So, trying to compile a pidgin plugin , say guifications, would result in a compile error saying : pidgin not found.
Old 17-03-2008, 02:55 PM   #8 (permalink)
The Smaller Bang
I will buy only AFTER atleast the blog part is finalised.
and there is 90% chance that I will meet the 31st deadline.
can I configure kompozer's publish button to publish directly to your server ?
All that learning I will do afterwards.
Old 17-03-2008, 03:02 PM   #9 (permalink)
Any software will work as long as it supports ftp uploads or frontpage extensions.
Old 17-03-2008, 03:19 PM   #10 (permalink)
slugger's Avatar
you can categorise posts in your blogger blog
i done that for my blog
slugger is offline
Old 17-03-2008, 03:22 PM   #11 (permalink)
j1n M@tt's Avatar
hey, am a moron when it comes to Linux ..........so can I ask u guys something??
Will Kompozer work with Windows??
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 17-03-2008, 03:24 PM   #12 (permalink)
Think Zen.
ray|raven's Avatar
^Yep, Kompozer's cross-platform.
http://superb-east.dl.sourceforge.ne...7.10-win32.zip
Btw,create your own thread, dont hijack this.
Old 17-03-2008, 03:28 PM   #13 (permalink)
j1n M@tt's Avatar
^^thanx
Is this better than Dreamwaver?? I know a little HTML and JavaScript........
j1n M@tt is offline
Old 17-03-2008, 03:31 PM   #14 (permalink)
Think Zen.
ray|raven's Avatar
^ As I said, please create your own thread, dont hijack this.
Old 17-03-2008, 04:05 PM   #15 (permalink)
 Macboy
goobimama's Avatar
@gautham: Blogger has labels right? They aren't too bad. Almost like categories...
Also try not to start of with a wizzywig editor. Cause you will most definitely come across problems later on that will take much more trouble fixing than if you know your HTML and CSS throughly. Use wizzywig only as a convenience and not an absolute tool.
And Dreamweaver...haven't used it in years...
I'm like a bird... :)
goobimama is offline
Old 17-03-2008, 04:08 PM   #16 (permalink)
slugger's Avatar
as long as you dont add more than one label to a post, your label is your category
slugger is offline
Old 17-03-2008, 05:05 PM   #17 (permalink)
The Smaller Bang
I indirectly asked if kompozer supports the thing that your site needs to be supported.
In Laymen's language:
Does KompoZer support FTP Uploads or FrontPage Extentions ?
Old 17-03-2008, 05:08 PM   #18 (permalink)
Think Zen.
ray|raven's Avatar
^Yes.Kompozer supports FTP Upload.
Old 17-03-2008, 05:12 PM   #19 (permalink)
Google Bot
Pathik's Avatar
@jinmatt why dont u try nvu.? And gautham y dont u use modded wp.?
Pathik is offline
Old 17-03-2008, 05:14 PM   #20 (permalink)
TechTin.com
ravi_9793's Avatar
WP will be best option for you.
You dont need to know any language for this.
Yes you can have a static website+ blog on same account like:
yoursite.com -> static site
blog.yoursite.com OR yoursite.com/blog -> your personal blog.
Sub-domain option will work only if your host provide this features.
ravi_9793 is offline
Old 17-03-2008, 05:16 PM   #21 (permalink)
Think Zen.
ray|raven's Avatar
Nvu's Dead. Kompozer takes over where Nvu left off.
Old 17-03-2008, 05:19 PM   #22 (permalink)
The Smaller Bang
so how do I get started with WordPress ?
Old 17-03-2008, 09:57 PM   #23 (permalink)
The Smaller Bang
bump ?
Old 17-03-2008, 10:00 PM   #24 (permalink)
 Macboy
goobimama's Avatar
Wordpress installation instructions are nicely laid out on the Wordpress.org site. Very easy to follow.
(Addicted is spelt with two Ds....)
Old 17-03-2008, 10:27 PM   #25 (permalink)
Another Brick in the Wall
drgrudge's Avatar
It's easy. Just buy a hosting, then goto the Fantastico and install WP. Just a single click will install WP.
drgrudge is offline
Old 17-03-2008, 10:44 PM   #26 (permalink)
TechTin.com
ravi_9793's Avatar
yes..installation using fantastico is very easy. Just a 2 min process. But your host should provide this feature.
Old 18-03-2008, 09:27 AM   #27 (permalink)
The Smaller Bang
OK, I got my money ready for hosting and will soon buy it.
But can I install wordpress within a website ?
I am planning to make my blog in the format www . blogname . mysite . in
Is it possible if I use my own domain name ?
I want to install wordpress right inside that particular sub domain.
Old 18-03-2008, 09:40 AM   #28 (permalink)
TechTin.com
ravi_9793's Avatar
Yes it possible to have your blog as sub-domain name, depending on feature provided by your host.
Old 18-03-2008, 09:50 AM   #29 (permalink)
The Smaller Bang
and what is the bandwidth such a site comsumes ?
Old 18-03-2008, 10:03 AM   #30 (permalink)
eWebGuru
ahref's Avatar
More traffic you have more bandwidth you will consume.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Promoting from Blog to Website! Suggestions needed... Kiran.dks QnA (read only) 153 28-12-2007 10:00 PM
Website designing n2casey QnA (read only) 23 27-11-2006 06:58 PM
website designing help needed rajeev1981 Software Q&A 18 26-08-2006 11:55 PM
Qs For Website Designing And Developing!! vipul QnA (read only) 1 26-07-2005 12:21 AM
Personal BLOG ankitjain QnA (read only) 2 13-04-2005 01:31 PM
