Old 16-03-2008, 01:40 PM   #1 (permalink)
Default IP address
Hi.
I ve got MTNL Triband DSL connection.
I want to know the actual IP address of my system.
The ipconfig command displays only the ;ocal IP : 192.168.1.2.
How do I find my IP address.?
Is it static or dynamic?
TY
Regards
Amit.
amitsaudy is offline
Old 16-03-2008, 02:51 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: IP address
192.168.1.2 is IP of your system, not the IP of your internet connection.
generally MTNL provide dynamic IP , if you want static IP, you have to pay extra for that. Call MTNL to know about your connection.
And to know your current IP, you can visit this site:
http://www.ip-adress.com/
ravi_9793 is offline
Old 01-04-2008, 04:03 PM   #3 (permalink)
TY for the info.
Regards
Amit.
Old 01-04-2008, 04:05 PM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
you can also use showmyip.com
Regards,
The Conqueror
The Conqueror is offline
Old 01-04-2008, 07:28 PM   #5 (permalink)
Hi
go to the web page of your router it will show you the public IP currently assigned to you
regards
imageek is offline
Old 01-04-2008, 11:28 PM   #6 (permalink)
Open Command Prompt......(Start --- Run --- cmd)
Now type netstat -n.
The IP which you see below the heading of Local Address is your IP address.
ico is offline
Old 02-04-2008, 07:49 AM   #7 (permalink)
I knew i was missing some easy way out...
so you finally have it
Regards
imageek is offline
What can u do with an IP address Mrinal Mohit Chit-Chat 13 06-12-2007 03:26 PM
How to remove 'Address' from the Address Bar in Explorer Toolbar? Samystic Software Q&A 12 31-03-2007 12:28 AM
Ip Address ????????? kool QnA (read only) 4 02-11-2006 08:56 AM
HOW TO PUT Other MAC Address... Chindi_Chor QnA (read only) 4 07-02-2006 04:54 AM
IP address deepakprabhakaran QnA (read only) 11 14-03-2005 11:55 PM
