Old 16-03-2008, 09:32 AM   #1 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Disable INSERT key
Hi all..
off lately i have getting this INSERT key pressed mistakenly and it becomesa a headachewhile typing...
is there a way to disable it??
i am using vista .....
and if possible also tell me how to do it on ubunut tooo
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 16-03-2008, 10:28 AM   #2 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Default Re: Disable INSERT key
in my keyboard there is no insert key
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 16-03-2008, 11:03 AM   #3 (permalink)
i am also planning to remove that f(_) cking key...
its irritating... but my keyboard willl look like a toothless grandma... thats why...
is there a way ???
Know My Thoughts..
Old 16-03-2008, 12:09 PM   #4 (permalink)
adi007's Avatar
i think i found something...
http://www.wikihow.com/Disable-the-I...Key-in-Windows
You are lazy...you could have just googled it...
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 16-03-2008, 01:21 PM   #5 (permalink)
hey i cant enter that binary value...
wht should i do ??
Know My Thoughts..
Old 16-03-2008, 01:31 PM   #6 (permalink)
adi007's Avatar
i suppose you mean you can't enter
"000000000000000002000000000052E000000000"
right..?
don't copy paste the thing..
enter 2 digits at a time..
adi007 is offline
Old 16-03-2008, 01:36 PM   #7 (permalink)
ok but there are alreay a 0000 present...
should i enter tthe above said excluding them .. or inclduing them??
Know My Thoughts..
Old 16-03-2008, 01:52 PM   #8 (permalink)
adi007's Avatar
hmmm...
That's good Q..
Do some Trail and error and you will find it out...
adi007 is offline
Old 16-03-2008, 01:54 PM   #9 (permalink)
playing with registry ???/
huh.. will do it
Know My Thoughts..
Old 16-03-2008, 03:00 PM   #10 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Try following code:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,52,e0,00,00,00,00
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 16-03-2008, 06:24 PM   #11 (permalink)
wht should i do
like where to put in ???
Know My Thoughts..
Old 16-03-2008, 06:37 PM   #12 (permalink)
adi007's Avatar
that's easy..
open notepad
copy paste the code given by VG
save the file as "reg.reg".... the quotes must be included..
double click the reg file...press ok...restart...test...post the result...give me 10$..that's all
adi007 is offline
Old 16-03-2008, 06:56 PM   #13 (permalink)
hey dude.. i like the way u reply... very funny... no offence .. i really admire it...
merged the reg file.. but need to restart...right now i cant.. will do later and reply .. here..
and thnks in advance if it works..
Know My Thoughts..
Old 17-03-2008, 09:01 AM   #14 (permalink)
it worked...!!!!
it worked....
attached the reg file tooo...
anybody want to remove that annoying key.. can use it...
thnks guys for helping me out...
File Type: zip reg.zip (252 Bytes, 0 views)
Know My Thoughts..
Old 17-03-2008, 12:20 PM   #15 (permalink)
adi007's Avatar
Hey what about my 10$ then..
adi007 is offline
how to insert ep 630 into ear..?? nix QnA (read only) 1 17-01-2008 11:35 PM
cant able to Insert automatically Binay 007 Hardware Q&A 3 27-04-2007 04:45 PM
when i insert cd i want uniqe icon jawwadsajid Software Q&A 2 07-03-2007 07:42 PM
help me in powerpoint. want to insert mu pkt3000 QnA (read only) 9 11-01-2007 08:40 PM
How to insert google ad in forum ? pop143 Internet & WWW 24 11-10-2006 06:02 PM
