Old 15-03-2008, 06:22 PM   #1 (permalink)
mr.geniius's Avatar
Default need help here
I have a sony wio laptop<<model vg-nr115e>>. in my laptop there is window vista installed. now i want to install window xp home edition. but i m unable to install the window because in boot section there is no option to boot from cd. please tell me the way with which i can install the window xp.
mr.geniius is offline
Old 15-03-2008, 06:24 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: need help here
Goto ur bios[f2/del @ startup] and set DVD/CD drive as the first booting device.
Pathik is offline
Old 15-03-2008, 09:39 PM   #3 (permalink)
mr.geniius's Avatar
booting starts but xp is not loading. there is still vista on my laptop. it gives an error << hardrive not found>>>
Old 15-03-2008, 09:45 PM   #4 (permalink)
evewin89's Avatar
y do u want 2 install XP
Evil Lives 4ever......
evewin89 is offline
Old 16-03-2008, 12:20 AM   #5 (permalink)
Google Bot
Pathik's Avatar
Enable IDE mode in ur bios. Or slipstream sata drivers in ur xp installation
Pathik is offline
Old 16-03-2008, 12:31 AM   #6 (permalink)
High without substance...
chicha's Avatar
if your laptop came with preinstalled vista then XP will not work, you will not get drivers, at least for almost all the brands i know off.
i am not too sure about sony.
what ever you do call the cust care ppl and ask them if that model supports XP or not.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
