Old 12-04-2005, 10:41 PM   #1 (permalink)
Default Memory Woes!!!
My System has 192 MB of RAM but it SHows only 191.Also the System's Pretty
Sluggish at times and some medium-duty applications like Working out
Excel formulae & macros too take Long time to compile.I don't use my PC
for Gaming or 3D modelling.OS is WIndows 98.I dfreagment regularly
and have McAfee as the AV.I BAsically use it for Browsing & Clean the
cache after every Session.I also Weed out Spyware etc Using Both SpyBot
& Ad-Aware.All Definitions are uptodate And even Windows Updates are all
Upto Date.
Adding to the Excel woes is that Sometimes Powerpoint Hangs and when
I use DAP,the Screen Color Changes Somewhat.(The Browser Window
becomes shaded & all Blurred,Taskbar icons become Black etc)
Degaussing Does'nt work.
Is there any Benchmarking tool that Will generate a report by which I can
know what is wrong and where?
Some Friend Suggested that the system might be infected by a Resident
Trojan that might be Causing the System Sluggishness but McAfee Did'nt
Find anything on Scanning.
I\'m a Racist........Fav Racer is Lance Armstrong :mrgreen:
I\'m a Fascist.......Fav Face is Aishwarya Rai :mrgreen:
prasadzmultiplex is offline
Old 13-04-2005, 12:10 AM   #2 (permalink)
swatkat's Avatar
RAM is shown as 191MB because another 1MB is shared by the onboard graphics controller. i think you have Intel 810 chipset mobo.
Get CCleaner and CleanUp! and run them in SAFE mode and delete all the files they find.
Get TrojanHunter Trial and run it and select all the Hard Disk Partitions and click "Full Scan".
Download HijackThis and unzip it to dedicated folder (like C:\HijackThisFolder\hijackthis.exe).
Then run it and click the button Do a System scan and save log file. HijackThis will perform a scan and saves the log file as hijackthis.log in the same folder where it is installed and it also opens the file automatically.
Copy the entire contents of the file and post it.
http://swatrant.blogspot.com/
swatkat is offline
Old 13-04-2005, 05:24 PM   #3 (permalink)
Here's the LogFile of Hijack This:
Logfile of HijackThis v1.99.1
Scan saved at 5:10:37 PM, on 4/13/05
Platform: Windows 98 SE (Win9x 4.10.2222A)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\SYSTEM\KERNEL32.DLL
C:\WINDOWS\SYSTEM\MSGSRV32.EXE
C:\WINDOWS\SYSTEM\SPOOL32.EXE
C:\WINDOWS\SYSTEM\MPREXE.EXE
C:\PROGRAM FILES\MCAFEE.COM\VSO\MCVSRTE.EXE
c:\windows\SYSTEM\KB891711\KB891711.EXE
C:\WINDOWS\SYSTEM\mmtask.tsk
C:\WINDOWS\EXPLORER.EXE
C:\WINDOWS\SYSTEM\SYSTRAY.EXE
C:\PROGRAM FILES\MCAFEE.COM\VSO\MCVSSHLD.EXE
C:\PROGRAM FILES\MCAFEE.COM\AGENT\MCAGENT.EXE
C:\PROGRAM FILES\MCAFEE.COM\VSO\MCVSESCN.EXE
C:\PROGRAM FILES\COMMON FILES\REAL\UPDATE_OB\REALSCHED.EXE
C:\WINDOWS\SYSTEM\WMIEXE.EXE
C:\WINDOWS\SYSTEM\MSTASK.EXE
C:\WINDOWS\SYSTEM\DDHELP.EXE
E:\HIJACK THIS\HIJACKTHIS.EXE
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://g.msn.com/0SEENUS/SAOS01
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\PROGRAM FILES\ADOBE\ACROBAT 6.0\READER\ACTIVEX\ACROIEHELPER.DLL
O3 - Toolbar: McAfee VirusScan - {BA52B914-B692-46c4-B683-905236F6F655} - C:\PROGRAM FILES\MCAFEE.COM\VSO\MCVSSHL.DLL
O3 - Toolbar: (no name) - {62999427-33FC-4baf-9C9C-BCE6BD127F08} - (no file)
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\SYSTEM\MSDXM.OCX
O4 - HKLM\..\Run: [SystemTray] SysTray.Exe
O4 - HKLM\..\Run: [VSOCheckTask] "C:\PROGRA~1\MCAFEE.COM\VSO\MCMNHDLR.EXE" /checktask
O4 - HKLM\..\Run: [VirusScan Online] "C:\PROGRA~1\MCAFEE.COM\VSO\mcvsshld.exe"
O4 - HKLM\..\Run: [MCAgentExe] C:\PROGRA~1\MCAFEE.COM\AGENT\mcagent.exe
O4 - HKLM\..\Run: [MCUpdateExe] C:\PROGRA~1\MCAFEE.COM\AGENT\MCUPDATE.EXE
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\RunServices: [McVsRte] C:\PROGRA~1\MCAFEE.COM\VSO\mcvsrte.exe /embedding
O4 - HKLM\..\RunServices: [KB891711] c:\windows\SYSTEM\KB891711\KB891711.EXE
O8 - Extra context menu item: &Download with &DAP - C:\PROGRA~1\DAP\dapextie.htm
O8 - Extra context menu item: Download &all with DAP - C:\PROGRA~1\DAP\dapextie2.htm
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRAM FILES\YAHOO!\MESSENGER\YPAGER.EXE
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRAM FILES\YAHOO!\MESSENGER\YPAGER.EXE
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\SYSTEM\MSJAVA.DLL
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\SYSTEM\MSJAVA.DLL
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - http://download.mcafee.com/molbin/shared/mcinsctl/en-us/4,0,0,83/mcinsctl.cab
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - http://download.mcafee.com/molbin/shared/mcgdmgr/en-us/1,0,0,20/mcgdmgr.cab
O16 - DPF: {EB387D2F-E27B-4D36-979E-847D1036C65D} (QDiagHUpdateObj Class) - http://h30043.www3.hp.com/hpdj/en/check/qdiagh.cab?325
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/MsnMessengerSetupDownloader.cab
O17 - HKLM\System\CCS\Services\VxD\MSTCP: Domain = saisoft
O17 - HKLM\System\CCS\Services\VxD\MSTCP: NameServer
BTW,the Trojan Hunter Did'nt find anything and also I Defragged the HDD
and Ran a Thorough VirusScan Check to no avail.
Still the system's Somehwat Sluggish.
Old 13-04-2005, 05:55 PM   #4 (permalink)
hpotter606's Avatar
I thinks you are using too much of security sofware.
It happend to me too. I was using NAV 2005, ZA firewall, Spybot, system mechanic. So the system got really slow.
Now i am using NAV 2004 and MS antispyware and windows firewall. So its pretty fast now. Earlier i used to defragment regularly. Now i dont defragment at all and still my computer works fine. I have turned off windows update too. So i dont do anything you do. I even install games. The only difference is i have 256 MB ram. It shows only 221 MB ram.
hpotter606 is offline
Old 13-04-2005, 06:28 PM   #5 (permalink)
I Only Have McAfee Security Center & Nothing Else.
Though I use SpyBot & AdAware for internet security.
That's alll.....
Old 13-04-2005, 06:41 PM   #6 (permalink)
why need title?
bharathbala2003's Avatar
log on the computer in safe mode and fix the following enteries..
bharathbala2003 is offline
Old 13-04-2005, 10:17 PM   #7 (permalink)
I Don't Understand....Where & How to change the Entries?
In Hijack itself?? And what Diff will it make?
Also How will I log on in Safe Mode on Win 98??
Old 13-04-2005, 11:56 PM   #8 (permalink)
swatkat's Avatar
Running processes:
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - http://download.mcafee.com/molbin/sh...3/mcinsctl.cab
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - http://download.mcafee.com/molbin/sh...20/mcgdmgr.cab
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/Ms...Downloader.cab
O17 - HKLM\System\CCS\Services\VxD\MSTCP: NameServer = 192.168.10.1
Reboot in SAFE ( Press F8 Key just before Windows starts up when you switch on the System, and from the menu choose "Safe mode" ) mode and then close all applcications. Run only HijackThis and select/check the red colored entry above. Then click "Fix".
Reboot to Normal mode.
Also, perform System File Checking once. Go to Start> Run and type sfc and press ENTER. Here click "Settings" and select the option "Check for deleted files" and click OK. Then click the radio button "Scan for altered files" and clikc "Start". If it finds any Corrupt/Missing files, you choose to RESTORE the files from installation CD ROM or Files.
swatkat is offline
Old 14-04-2005, 05:43 PM   #9 (permalink)
Swatkatji,When I run the HijackThis in Safe Mode,I don't get the Red Labelled
Entry.Here's the New logfile.....
Scan saved at 5:27:28 PM, on 4/14/05
Running processes:
O4 - HKLM\..\Run: [mcupdmgr.exe] C:\PROGRAM FILES\MCAFEE.COM\AGENT\MCUPDMGR.EXE
O8 - Extra context menu item: &Download with &DAP - E:\PROGRA~1\DAP\dapextie.htm
O8 - Extra context menu item: Download &all with DAP - E:\PROGRA~1\DAP\dapextie2.htm
Old 14-04-2005, 06:50 PM   #10 (permalink)
swatkat's Avatar
hmm...have you performed SFC?
Get ToolBarCop and post a screenshot of it running.
http://windowsxp.mvps.org/toolbarcop.htm
swatkat is offline
Old 14-04-2005, 08:54 PM   #11 (permalink)
I have Run SFC and had to Reinstall two files named user.exe and setup.dll.
I have also run the ToolbarCop and here is itz Screenshot:
Here is the report it generated:
ToolbarCop - Browser Add-on Report
Browser Extension: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRAM FILES\YAHOO!\MESSENGER\YPAGER.EXE - Enabled - All Users
Browser Extension: n/a - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\SYSTEM\MSJAVA.DLL - Enabled - All Users
Toolbar: &Address - {01E04581-4EEE-11D0-BFE9-00AA005B4383} - C:\WINDOWS\SYSTEM\BROWSEUI.DLL - Enabled - Current User
Toolbar: &Links - {0E5CBF21-D15F-11D0-8301-00AA005B4383} - C:\WINDOWS\SYSTEM\BROWSEUI.DLL - Enabled - Current User
Toolbar: (Empty) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - (empty) - Enabled - Current User
Toolbar: (Empty) - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - (empty) - Enabled - Current User
Toolbar: McAfee VirusScan - {BA52B914-B692-46C4-B683-905236F6F655} - C:\PROGRAM FILES\MCAFEE.COM\VSO\MCVSSHL.DLL - Enabled - All Users
Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\SYSTEM\MSDXM.OCX - Enabled - All Users
BHO:  - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll - Enabled - All Users
BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\PROGRAM FILES\ADOBE\ACROBAT 6.0\READER\ACTIVEX\ACROIEHELPER.DLL - Enabled - All Users
Name-Space HTTPS: ZDA - {5BFA1DAF-5EDC-11D2-959E-00C00C02DA5E} - (empty) - Enabled - All Users
Menu Extension: &Download with &DAP -  - E:\PROGRA~1\DAP\dapextie.htm - Enabled - Current User
Menu Extension: Download &all with DAP -  - E:\PROGRA~1\DAP\dapextie2.htm - Enabled - Current User
Menu Extension: Download with GetRight -  - C:\Program Files\GetRight\GRdownload.htm - Enabled - Current User
Menu Extension: Open with GetRight Browser -  - C:\Program Files\GetRight\GRbrowse.htm - Enabled - Current User
Run - Startup: SystemTray -  - SysTray.Exe - Enabled - All Users
Run - Startup: VSOCheckTask -  - "C:\PROGRA~1\MCAFEE.COM\VSO\MCMNHDLR.EXE" /checktask - Enabled - All Users
Run - Startup: VirusScan Online -  - "C:\PROGRA~1\MCAFEE.COM\VSO\mcvsshld.exe" - Enabled - All Users
Run - Startup: MCAgentExe -  - C:\PROGRA~1\MCAFEE.COM\AGENT\mcagent.exe - Enabled - All Users
Run - Startup: MCUpdateExe -  - C:\PROGRA~1\MCAFEE.COM\AGENT\MCUPDATE.EXE - Enabled - All Users
Run - Startup: TkBellExe -  - "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot - Enabled - All Users
Run - Startup: mcupdmgr.exe -  - C:\PROGRAM FILES\MCAFEE.COM\AGENT\MCUPDMGR.EXE - Enabled - All Users
List of running Processes
C:\PROGRAM FILES\MCAFEE.COM\VSO\MCVSFTSN.EXE
C:\PROGRAM FILES\INTERNET EXPLORER\IEXPLORE.EXE
C:\PROGRAM FILES\MAXTHON\MAXTHON.EXE
C:\PROGRAM FILES\MOZILLA FIREFOX\FIREFOX.EXE
C:\WINDOWS\SYSTEM\PSTORES.EXE
C:\PROGRAM FILES\GETRIGHT\GETRIGHT.EXE
E:\TOOLBARCOP\TOOLBARCOP.EXE
Operating System details
Operating System: Windows 98 4.10
Build: 2222
Service Pack level:  A
Old 15-04-2005, 12:37 AM   #12 (permalink)
swatkat's Avatar
Boot in SAFE mode and close all applications and run ToolBarCop and right-click and delete the items inside red box.
swatkat is offline
Old 15-04-2005, 10:55 PM   #13 (permalink)
Swatkatji,
I am Unable to Boot into Safe mode.Whenever I press F8 while Bootup,
The "Boot Device Selection" menu opens up.I see the list as:
Hard Drive
CD-ROM or Other removable Device
Network Boot
Boot on Lan
<Exit>
and I have to select one of the above options.......
I restarted almost 6-7 Times but to no avail.I also tried the Ctrl Key.....
Is there no other way to boot into Safe mode?
Also Can't the Process Outlined by u be done in Normal Mode?
I am sorry that I am asking so many Q's and Hope u Don'Mind.
Thanks for what you have done for me till now.....
Old 15-04-2005, 11:39 PM   #14 (permalink)
swatkat's Avatar
Ok, you can do the removal using ToolBarCop in Normal Mode, but close all Browsers and Programs.
swatkat is offline
Old 26-04-2005, 09:02 PM   #15 (permalink)
Did that Swatkatji and Now it seems that my PC is fine.Altho it is more of a Psychological thing,I think it is ok now.
Now it remains to see how it will be under some HEavy-Duty Apps....
