Old 13-03-2008, 11:13 PM   #1 (permalink)
Default login and logout
hai friends
Consider that i am logging into my yahoo mail account.So what's the difference between logging out from my mail id and simply closing the mail id window.Is both r same or do they create any difference
sakthikns is offline
Old 13-03-2008, 11:21 PM   #2 (permalink)
hullap's Avatar
Default Re: login and logout
by loggin out u get ur cookies deleted and if u just close the window there is a possibility that opening it afterwards u might be logged in
hullap is offline
Old 14-03-2008, 06:54 PM   #3 (permalink)
If you accidently check the box next to KEEP ME SIGNED IN FOR TWO WEEKS and just close the window without logging out, anyone can see the mails lying in your account and may even send mails if he gets access to your computer.
ThinkFree is offline
HELP! HELP! HELP! I can't login!!!!!! The Unknown Open Source 21 18-07-2007 10:08 PM
Sify Login App Help ashfame Software Q&A 9 27-05-2007 10:31 PM
xp is auto logout immediately after login - pls help kumaran Software Q&A 12 11-09-2005 04:17 PM
Logout Code sid_b6505 QnA (read only) 2 30-06-2005 05:01 PM
