Old 13-03-2008, 11:09 PM   #1 (permalink)
Default security algorithm
hai friends
I am doing my higher studies in INFORMATION SECURITY.I have one doudt ,there r many security algorithm like DES ,AES,RSA.So what's the major cretiria which is used to compare one security algorithm with another.Which factor decides one algorithm is secure over another.Some of my friends said that it's the attack which decides the security level of the system.But i didnt find any proof for that.But in the books the security level is compared only based on the key size, and the time required to break the key.So pls friends tell which is the major factor which decides the security level of an algortihm.which factors are used to compare security algorithm.
sakthikns is offline
Old 13-03-2008, 11:46 PM   #2 (permalink)
I see right through you.
Sykora's Avatar
Default Re: security algorithm
Encryption algorithms are generally compared by the time taken to break the key, followed by the size of the key for comparable security.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 13-03-2008, 11:56 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Yup generally if the size and encryption method is good, the time taken to brute it ll be too much. That ll be a great plus
Pathik is offline
Old 14-03-2008, 02:25 AM   #4 (permalink)
its the one sidedness of the encryption, i.e. u can go one way not the reverse way along with key size and the salt added.
Faun is offline
Old 14-03-2008, 07:31 AM   #5 (permalink)
@sakthikns
which college are u doin ur course in? and is it like M.S Comp Sci or something like that.... becoz information security sounds really interesting..
sai_cool is offline
Old 25-03-2008, 07:26 PM   #6 (permalink)
Mad and Furious
redhat's Avatar
BUMP::
Is there any site where we can test encryption algorithms??
Like, if I have made one algorith and want to see how strong it is, where should I head to??
redhat is offline
Old 25-03-2008, 07:40 PM   #7 (permalink)
post it here
let me give it a try
sreenidhi88 is offline
Old 26-03-2008, 06:33 AM   #8 (permalink)
Mad and Furious
redhat's Avatar
Well, I havent yet completed the encoding, will finish in some time...
I got delayed due to my Std. 10 board exams this month...
Neways, Just curious, how will you try to crack my encryption?
If you could explain the procedure of reverse engineering that you will use...
You want me to post the riginal string alongwith the encrypted one??
redhat is offline
Old 26-03-2008, 07:30 PM   #9 (permalink)
choudang's Avatar
this is not a professional question as you are belong to IS. you can not ask "how you will do" before completing you project. if you get the answer .. all knows that you will block that part. post it here or else, let us try to break it and post the reasons... that will be the best part.....
For every action, there is an equal and opposite criticism.
choudang is offline
Old 26-03-2008, 07:34 PM   #10 (permalink)
Mad and Furious
redhat's Avatar
^^Accepted, My board exams are getting over on 28th, will be out with friends for a day or two,
As soon Im back, I will finish making this encryption software, but please tell me, do you want the original String too?
More-over, this algorithm has a user password too....
redhat is offline
Optimize the algorithm Faun Open Source 1 08-03-2008 06:42 PM
mp3 decoding algorithm setharsh Software Q&A 1 05-06-2007 02:28 PM
algorithm maker fanatic Software Q&A 3 25-03-2006 10:17 PM
graphic algorithm shivi4 Graphic cards 1 26-12-2005 10:22 PM
