Old 12-04-2005, 06:01 PM   #1 (permalink)
Default MSN32.dll error
I have a computer with win98 OS. When i start computer on the time of displaying desktop it gives a message "msn32.dll error". n after pressing OK it starts. now how can i disapear that message?
Hey I am cool..........
kamaal is offline
Old 13-04-2005, 11:39 AM   #2 (permalink)
club_pranay's Avatar
r u sure it's not msnp32.dll??(try google)
well, it looks like a msn messenger file. try re installing msn. also post Hijack this log file http://www.merijn.org/files/hijackthis.zip
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 13-04-2005, 04:43 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
It is msnp32.dll.
Download this file from http://www.dll-files.com/dllindex/dl...s.shtml?msnp32.
Put the file in the windows\system directory.
But this is not done, You will need to remove the Dial Up Networking component from Windows Setup, reboot your system, and then add the Dial Up Networking component back using Windows Setup, follow that with one more reboot and then u are done.
To remove the Networking component,
go into Add/Remove Programs from the Control Panel Double Click on Network
Click on Microsoft Network (where it says "the following network components are installed")to highlight it
Click on REMOVE
a message is going to tell you that your network is not complete and it will ask you if u want to continue anyways.....Click "OK" to continue removing the component.
it will ask you to restart click ok
after you reboot you will not see the message.
for more info Must look:
http://www.computing.net/windows95/w...orum/1613.html
http://computing.net/windows95/wwwbo...um/141645.html
http://forums.pcworld.co.nz/archive/...p/t-50206.html
http://www.computing.net/windows95/w...um/143414.html
navjotjsingh is offline
