Old 12-04-2005, 08:19 AM   #1 (permalink)
foreign return(0)
comrade's Avatar
Default Dataone connection sharing
i got 2 ethernet card one for the modem and the other for my home network.
i use ccproxy for internet connection sharing.
i found no prob in accessing webpages thru my system which is directly connected to the internet. But other systems that are behind the proxy found to be not so fast as the one which has direct access.
any tweak needs to be done? ive disabled the firewalls too.
comrade is offline
Old 12-04-2005, 01:04 PM   #2 (permalink)
Let the music play.....
djmykey's Avatar
comrade can u share the settings how u managed to share it coz i need to share the connection as well pls man.
djmykey is offline
Old 12-04-2005, 04:49 PM   #3 (permalink)
unfortunately all ur systems behing the proxy will be slower
atleast by a margin
sicne its internet connection sharing not full bandwidth is given to the proxy server part of ur host ...
u could try other software or even inbuilt ICS for improvement
i suggest trial and error till u are satisfied ..
check my tutorial in the tutorial section
"how to share a net connection over a LAN "
No Mercy, No Limits.
theraven is offline
Old 12-04-2005, 09:02 PM   #4 (permalink)
foreign return(0)
comrade's Avatar
Here is what I’ve done for connection sharing. I do agree that this one is not the best but can give u an idea for an ideal setup.
I assume that u have 2 ethernet cards. In my case I have an inbuilt NIC which is connected to adsl modem. The second card is the addon NIC to interconnect the network.
Open control panel -> network connections. u should have something like this.
Right click the inbuilt lan connection or the one connected to the adsl modem and select properties. Make sure ppp over Ethernet is selected while others unselected.
Right click the other lan connection, select properties and configure it to look like this.
Configure local IP address for this lan if not done.
Now run a proxy server. Any proxy will do, no configuration is necessary for basic usage. Look for free proxy in april 2k5 digit cd/dvd.
No go to the system that require net access and configure ur browser settings something similar to this.
Done.
for a complete setup please do refer this link
http://www.windowsnetworking.com/pag...le_p.asp?id=26
comrade is offline
Old 12-04-2005, 09:11 PM   #5 (permalink)
foreign return(0)
comrade's Avatar
atleast by a margin
i can tolerate a slight slow down. but in my case the systems are not even opening the html pages properly(i found dialup a lot better) although using download manager i was able to achieve faster downloads as same as the true one.
do i need to perform any modification to tcp/ip settings/ browser settings/proxy itself.
comrade is offline
Old 12-04-2005, 09:24 PM   #6 (permalink)
Sorry if I may have missed it but is the "slowdown" w.r.t to only accesing web pages ?
When you try accessing the internet what activity is taking place at the proxy server[your host pc]?
If the proxy server itself is continously downloading something or making maximum usage of available bandwidth then balancing bandwidth between the proxy server & the other host pc may be the issue.Just reduce all internet activity at the proxy server & try accessing web page,or download from the host pc.
www.Oobertech.net
digen is offline
