Old 12-03-2008, 02:59 PM   #1 (permalink)
vikasg03's Avatar
Default Why quality reduce during rendering.
Hy,
from my friend canon Handicam i shoot one video for 1 hour. (In panasonic DV tape ) When i connect to tv or laptop it was very great quality . You can say 100% good clear picture, but when i copy into my laptop through ulead s/w as a dvd, the quality reduced , tremendusly . So i went mkt and give a tape to one good camera shop person and ask him to convert the tape into dvd. But result was same. He told me we cannot achive a same quality which is in Tape . Quality reduced due to rendering. Is is true. Or any software whether paid or trial gives a same quality which are in handicam tape
Vikas
Vikas
vikasg03 is offline
Old 12-03-2008, 08:37 PM   #2 (permalink)
Default Re: Why quality reduce during rendering.
It depend on the format to which the video is rendered. You cant expect a DV quality from a dvd or vcd
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
Old 12-03-2008, 08:49 PM   #3 (permalink)
www.VideoEditingIndia.com
VideoEditingIndia's Avatar
Its all depends on the MPEG-2 encoder, you used. Ulead has a built-in encoder which is a s###
All DVDs uses the same format, MPEG-2. But if your original footage is good, you can get up to the Hollywood DVD quality. Can you post a sample video?
TATASafariClub.com - Its only for MEN - News, Tips, Photos & Guidelines for Men!
VideoEditingIndia.com - Film, Audio, Video Editing & Compositing - Get movie Night Right!
VideoEditingIndia is offline
Is there a software Reduce Quality of ogg files in multiple folders ilugd Software Q&A 3 09-12-2006 10:03 PM
HDR Rendering ionicsachin QnA (read only) 1 26-05-2006 05:17 PM
poor quality rendering rajesh_nk22 QnA (read only) 9 12-05-2006 01:19 PM
IE7 Rendering problem. saurabh.sauron Software Q&A 8 12-02-2006 01:16 PM
