Old 12-04-2005, 01:11 AM   #1 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Default MSN Login... Hacked ??
Eversince I installed MSN Messenger 7, and login to using my MSN ID it gives me an alert "you're logged in to another machine..." and then it signs me off.
And I'm not able to login... but at the same time, I'm able to check my mails on the same MSN ID using IE, Firefox & Opera, on the same computer of diff computer.
I'm wondering how'z this possible!!!???
I use MSN Messenger mostly with my college friends and most of times from CCC here.
Also I've checked that none of system I use in CCC are automatically registered for the same .NET Passport [my MSN ID]
Am I hacked, but how!!??
Or is it some bug in MSN 7??
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 12-04-2005, 12:27 PM   #2 (permalink)
why need title?
bharathbala2003's Avatar
i dont think its a bug in msn.. cos i ve been usin it for a few months and its fine.. try changin ya pass m8..
bharathbala2003 is offline
Old 12-04-2005, 03:08 PM   #3 (permalink)
How about logging into your email account and changing your password, while you are at it change the reminder answer aswell. Hope this helps.
redalert5 is offline
Old 12-04-2005, 03:13 PM   #4 (permalink)
sekhar,
Are you using windows XP ? If so then windows XP comes with a builtin messenger which might be causing the different machine login. So check that.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 12-04-2005, 03:14 PM   #5 (permalink)
Default Re: MSN Login... Hacked ??
Holy **** i think u are hacked .... (by msnfunmaker)
Just uninstall the msn messenger and also change yo pass and persnal info
This is my personel advice
BTW dont accept files (any extension) and dont show webcam during chat.
h4xbox is offline
Old 12-04-2005, 03:39 PM   #6 (permalink)
chinmay's Avatar
Hey Shekhar.....i dun think u r hacked....hotmail passport is a pretty secured thing n is v.difficult to hack....i think either ne1 has seen u typin da password or u hv left any comp in cyber cafe or office in "Sign Me In Automatically" mode...in this mode ne 1 can sign in ur id in that comp....if this is not da problem then its possibly "windows Messenger" which automatically signs u in ur comp only b4 u sign in thru msn messenger....in any case as soon as u change ur password ur problem will be solved.....in da worst case even if ur passport is hacked changin of passwordwill solve it...but to avoid future attacks plz put any firewall in ur comp like norton or sygate....mcaffe sux so dun put it...remember firewall is diff. from antivirus so check properly its firewall only....and also put digits in ur password bcuz password with digit is extremely to hack and most of hackers cant hack it....
enjoy....
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 12-04-2005, 03:48 PM   #7 (permalink)
chinmay's Avatar
h4xbox.....u r doin wrong to mankind...this is all ihv got to say...newayz...sorry.....jus temme how u know i study in 12th
chinmay is offline
Old 12-04-2005, 04:52 PM   #8 (permalink)
nah it happens
it happens with my yahoo
and it happened with a friends msn
i dunno what the problem is .... but i shifted t gaim because of it
msn works fine for me ... and yahoo gives problem only on my laptop !!
i even reinstalled and it didnt go away
infact as soon as i used to sign in it signed me off ...
weird ....
im sorry i cant be of much help .. but to test whether its really hacked or not use a multi protocol IM like gaim and check it out if u get the same msg again
No Mercy, No Limits.
theraven is offline
Old 13-04-2005, 12:13 AM   #9 (permalink)
Web Entrepreneur
thnx all... I re-searched today in noon!
there was system, node 03c, where i used to sit cupl of weeks ago just for cheking mails and stuff during lunch... and I found that Explorer associated my .NET Passport with that machine, 'coz once I used Windows Messenger 3-4 weeks ago on tht machine.... so whenever I try to start MSN 7 on any other machine it disconnects me with tht alert 'coz i'm already connected thru Messenger Service of that node...
Removed everything, also changed my pwd now
thanx for info & sugessions
Old 18-04-2005, 05:43 PM   #10 (permalink)
Edit[Nemesis]: Watch what you say here. This is a warning for you.
If he challenges u will u be calm.... ?? temme mr.nemesis
h4xbox is offline
