Old 12-03-2008, 09:31 AM   #1 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default cassettes to cds
Plz tell me hw 2 cinvert cds. Wht r the requirements. Plz tell me. Plz explain me in detail
JohnephSi is offline
Old 12-03-2008, 02:14 PM   #2 (permalink)
Mobile Freak
reddick's Avatar
Default Re: cassettes to cds
I have read this procedure in one of the DIGIT issue of Oct. month but don't know d yr. May b of 2006 or 07
U may take a look @ that old mags
Hope 4 d best n Do d right :)
reddick is offline
Old 12-03-2008, 02:20 PM   #3 (permalink)
Elevating Humanity
The Conqueror's Avatar
IMHO Better buy the CDs of the cassettes u need.
There i one more way :
Requirements - Headphone,cassette player,cassettes and pc
1. Start the cassette player
2. Put the cassette in it
3. Switch on ur headphone.
4. Make ur cassete player on HIGH volume
5. Start Recording and save it in mp3
I know its a lame method . You can use softwares like Windows Sound Recorder or Audacity etc to record
Regards,
The Conqueror
The Conqueror is offline
Old 12-03-2008, 07:02 PM   #4 (permalink)
parthbarot's Avatar
crap man... this is not the way yaar...
-First, check that you tape got Line-out pins.
-Then buy an cable having 2 line-out and one mic-in for your pc.
-joint your tape's line-out with your PC's Mic-in pin through the cable.
-Then start your tape and record the voice in any recording software.
If you have problem finding the cable, just get your tape and goto any tv/electronics repair shop.You will get the cable in some 30 to 50 Rs.
This way you will get good quality in audio.
best of luck.
Paarth.
www.techlads.com
Paarth.
parthbarot is offline
Prob in making VCDs frm handycam cassettes mayur_digitized Mobiles and Tablets 2 18-05-2007 05:44 PM
Software to record voice on Cassettes ? paragkalra Software Q&A 3 24-10-2006 10:54 PM
Software for converting Video Cassettes to DVD/CD's Charley Software Q&A 14 23-02-2005 10:40 PM
converting cassettes to mp3 sAr Software Q&A 16 18-08-2004 03:59 AM
