I discovered something strange when downloading the free MOPY screensaver
from HP. (you can Google it yourself and test it out)
The download file is only 1.30MB (it was originally made to be easily distributed
on FLOPPY (yes Floppy) disks) and uncompressing takes a long time (for such
a small screensaver..) but it unpacks to over 8MB!
Now when I try to COMPRESS the MOPYFISH folder back again with the
compression utilities below I get nothing remotely NEAR the compression
level of the original distribution.
MOPYFISH folder 8.85MB
MOPYFISH.zip - 4381KB
MOPYFISH.rar - 4009KB
MOPYFISH.7z - 3671KB
How is it possible they packed the whole thing in only 1.30MB? Is this a
special tool they wrote specifically for the program and if so why can't
we use such an algorithm to pack all programs might tighter??
Seriously test it out yourself.
Download the screensaver at
http://www.mopyfish.net/
Get winzip at
http://www.winzip.com/prod_down.htmWinrar at
http://www.rarlab.com/7-zip at
http://www.7-zip.org/
Whatever you no you will NOT be able to get that 8.5mb program back into the 1.30mb that it came out from!!!!
I'd like to know WHY is this? So is it possible for me to write a program that is 80MB and pack it into only 10MB?
