Old 11-03-2008, 11:54 PM   #1 (permalink)
Default Cant restart or shutdown! Plz help
Hello all! Iam stuck with a weird problem! Iam not able 2 restart or shutdown or log off my windows xp!! Even programs requiring restart cant do it!! Plz help.... The problem came wen i was following vg guide 2 transform xp 2 vista luks. Dont know wer i went wrong. May b vth da logon part!! So any1 plz help!
bhadkow is offline
Old 12-03-2008, 02:25 AM   #2 (permalink)
evewin89's Avatar
Default Re: Cant restart or shutdown! Plz help
hav u tried system restore?
Evil Lives 4ever......
evewin89 is offline
Old 12-03-2008, 02:30 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Seems like you have messed up with msgina.dll file. If you can boot into Safe Mode, then you can restore the original file which will be present in the same directory with the name "msgina_original.dll".
Other easier method would be to repair Windows installation using XP CD. It'll just replace edited system files with original ones.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Shutdown = Restart ??????? codename_romeo Software Q&A 14 20-12-2007 06:17 PM
Shutdown instead of Restart lahratla QnA (read only) 4 23-10-2005 12:02 AM
Shutdown ur pc to restart it !!!!!!! abhi1234 QnA (read only) 5 30-04-2005 07:44 PM
Fast restart & shutdown Neil QnA (read only) 4 30-12-2004 12:05 AM
shutdown = restart simplegeek QnA (read only) 1 28-11-2004 07:11 PM
